grinding when stepping on clutch pedal
I'm getting a grinding noise when i step on my clutch pedal almost all the way. Everything was fine... i was driving and all of a sudden i was barely getting into gear and when i stepped on my clutch pedal it started grinding. What could be the problem? I'm running a gsr tranny with a tilton twin disk clutch.
twin discs have floating discs...are you sure youre not hearing them float? it also may be the disc hitting the flywheel bolts...check and make sure you have a clutch pedal stop. i had some of the same issues
brett
brett
i know how a twin disk clutch sound like... this was what happened
https://honda-tech.com/zerothread?id=1661698
