rebuilding block, need help!!
i am currently rebuilding an ls motor and i came upon a couple problems.
first, i want to reuse my stock pistons but two of them are scratched slightly on the side. when u slide ur finger nail u can bearly feel it. should i use the pistons or just buy new ones?
second is when i tried to screw on one of the main bearing bolts it didnt screw on easely and i forced it and messed up the thread. how would i be able to fix this and be sure it is going to be safe and hold.
third is i bought .25 os rings and if i do use my stock pistons can i just file down the rings til the gap is to specs?
any help appriciated
Uhhh.. wow.
Don't reuse stock pistons.
Buy oversized pistons since you already have oversized rings.
Bore and hone to 81.25mm.
Main bolt fucked or actual main? .. If it's the bolt, get a new one.. if it's the actual thread in the main.. it's possible that the block is junk.. may be possible to run a tap through it depending on how bad it is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccivic »</TD></TR><TR><TD CLASS="quote">Uhhh.. wow.
Main bolt fucked or actual main? .. If it's the bolt, get a new one.. if it's the actual thread in the main.. it's possible that the block is junk.. may be possible to run a tap through it depending on how bad it is.</TD></TR></TABLE>
ok. its the actual thread on the block. i dont know how bad it is, but i can just screw the bolt in like 2 or 3 turns than i can do it no more by hand. dont know how bad that it.
5thgencivic
Nov 29, 2003 03:26 PM
