96civic sedan trunk wont shut all the way
Old Jun 14, 2006 | 09:51 PM
Jlamar757's Avatar
Default 96civic sedan trunk wont shut all the way
My trunk closes and water does not leak..But, it kinda of sticks up alittle on the left side. It has more of a raised look and does not completely close.
Any help would be much appreciated.
Old Jun 14, 2006 | 09:56 PM
JDM-EJ1's Avatar
Default Re: 96civic sedan trunk wont shut all the way (Jlamar757)
Make sure there is nothing between the trunk arms and the trunk. Also, check to see if that one trunk arm is bent, causing it be raised in one area.
Old Jun 14, 2006 | 10:03 PM
Jlamar757's Avatar
Default Re: 96civic sedan trunk wont shut all the way (JDM-EJ1)
thanks. ill check
any more suggestions?
Old Jun 14, 2006 | 10:06 PM
Mac2118's Avatar
if it's just the one side that is up, there's little black "*****" that let you adjust the "tightness" of your trunk lid to your car. check to see that they are screwed in at the same depth (I usually count the little "strips" from the main rubber part to the trunk lid itself
Old Jun 14, 2006 | 10:12 PM
Br1anPham's Avatar
Default Re: (Mac2118)
I've seen body shops actually alter the hole (make it bigger) to increase the amount of play where the truck mounts onto the big hinges (trunk arms) to help aling it before bolting it down. It worked when they aligned my brothers car after he was rear ended. The trunk lines up perfectly.
You didnt get a flipflop trunk as well, did you? jp
Modified by Br1anPham at 11:24 PM 6/14/2006
Old Jun 14, 2006 | 10:22 PM
Mac2118's Avatar
who? me?
lol man.. what's a trunk?
http://memimage.cardomain.net/...l.jpg
Old Jun 15, 2006 | 01:03 AM
Jlamar757's Avatar
hey i remember you. i use to aim you for civic advice. jlamar757
99 TW EJ8
Paint and Body
Oct 14, 2009 08:11 AM
ZXRider
Oct 20, 2008 08:50 AM
00ekcoupe
Mar 6, 2006 06:39 PM
Stellar1
Feb 25, 2003 08:28 AM
96 SOHC VTEC
Jan 8, 2003 02:01 PM
