Bad Clutch Master Cylinder?
hey guys need a little help, i did some searching and i believe i have come to a conclusion.
heres why i think this:
where hard line meets the the soft line off the slave cylinder i had a small leak from not tighting it down well enough, draining all the fluid to where the clutch pedal would hit the floor. infact before i found this out the car came to a halt while pulling out of my driveway and was stuck in reverse.
before it did this sometimes the clutch pedal would get stuck half way while ascending after letting my foot off the clutch.
and i know for a face the clutch pedal has hit the floor a few times. doesn't this usually cause the mc to fail?
i tried to rebleed the line and not once did i get any pressure at the pedal after it got stuck in reverse.
can anyone confirm that my mc is bad? thanks.
well check to see if its leaking under the dash cause mine does the same thing. also if you o ver torqued the 8mm on the slave cylinder itll leak too
well i checked for leaking under the dash and it didn't seem wet, however it was a little bit rusty down there so maybe it does leak? as well the hard line off the slave was never removed, just the trasition from the hard line to the soft line. thanks.
hYbRiD EeEkAy
Aug 7, 2008 11:27 AM
JimmyAtlantis
Jun 2, 2006 08:55 AM
