CIVIC IDLE CONTROL VALVE QUESTION
Old Jun 14, 2006 | 01:46 PM
GdmLaz's Avatar
Default CIVIC IDLE CONTROL VALVE QUESTION
K this is my question why are there 2 idle control valves the one under the throttle body "THE Fast Idle Thermo Valve"" that has the spring or w.e inside and the one that goes behind th Intake manifold the ICV the black looking 1 whats the difference between both of them
Modified by GdmBlk99SI at 10:52 AM 6/15/2006
Old Jun 14, 2006 | 02:32 PM
GdmLaz's Avatar
top top top
Old Jun 14, 2006 | 02:37 PM
alacard's Avatar
Default Re: CIVIC IDLE CONTROL VALVE QUESTION (GdmBlk99SI)
im pretty sure youre getting one confused with something...depending on what year and trim you have..i think there should only be one...
bump for someone with a better answer
Old Jun 14, 2006 | 07:04 PM
streetsold6teeny8's Avatar
https://honda-tech.com/zerothread/1657104
Laz this is the thing i bought
Old Jun 14, 2006 | 07:22 PM
nekoabandoned's Avatar
Default Re: (streetsold6teeny8)
ur just all over the forum tonight
Old Jun 14, 2006 | 07:30 PM
whose all over the forums??
Old Jun 14, 2006 | 07:33 PM
sicones's Avatar
the "black thing" on the back of the throttle body with a 3 pin plug is your TPS (throttle position sensor)
Old Jun 15, 2006 | 06:50 AM
GdmLaz's Avatar
and i was talkin about the ICV AND THE Fast Idle Thermo Valve whats the difference between them
Old Jun 15, 2006 | 07:30 AM
EE_Chris's Avatar
Default Re: (GdmBlk99SI)
FITV is mechanical, IACV is electrical. FITV is used during cold starts or until the coolant is hot enough to make the wax pellet expand enough to seal off the air passage into the intake manifold. The IACV is then used by the ECU to control the idle.
Old Jun 15, 2006 | 07:52 AM
sicones's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GdmBlk99SI &raquo;</TD></TR><TR><TD CLASS="quote">and i was talkin about the ICV AND THE Fast Idle Thermo Valve whats the difference between them</TD></TR></TABLE>
maybe you should be a little more specific then "black looking 1"
Old Jun 15, 2006 | 08:20 AM
GdmLaz's Avatar
Default Re: (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">
maybe you should be a little more specific then "black looking 1"</TD></TR></TABLE>
SORRY MASTER I COULDN'T REMEMBER THE NAME WHEN I WROTE IT LOL lmFAO so what happens if you take the FAST IDLE THERMO VALVE OFF will the car still be able to idle ?
im reffering to this thread https://honda-tech.com/zerothread/1657104
Old Jun 15, 2006 | 08:33 AM
EE_Chris's Avatar
If you take it off, you won't have the additional air flow that it was providing during cold starts. So really the question is: How cold can it be where FITV operation isn't really needed? And in that thread, one guy states "If you're living in CA, you won't need it", so there's an answer. I'd say if you're living up north, you'd need it.
So yes, with the FITV off the car, it will still be able to idle just fine when warmed up since the FITV is basically disabled. It's cold idle operation that will be effected.
Old Jun 15, 2006 | 08:53 AM
GdmLaz's Avatar
k so when the car is cold it'll basically idle like **** correct ?
Old Jun 15, 2006 | 08:58 AM
EE_Chris's Avatar
Yep. And if happens to not idle at all in the cold (when starting up), well, you've got a potential reason.
Old Jun 15, 2006 | 09:18 AM
GdmLaz's Avatar
yea thats what i figured because i saw people selling this block off plate or w.e but from what i had heard was that the fitv was the one that handled the idle during start and when the car was hot then the iacv took over so without the fitv the car should not idle at all during cold it should go crazy
blakdeth77
Jan 9, 2009 12:54 PM
wondersparrow
May 10, 2008 05:41 PM
h22vt
Apr 20, 2006 09:34 AM
smash fascism
Apr 10, 2005 06:39 AM
