changing wheel studs on 89 accord
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by micalguy »</TD></TR><TR><TD CLASS="quote">trying to change wheel studs. can't get axle nut off. any suggestions?</TD></TR></TABLE>
I assume you've tried a 1/2 impact gun on an air line?
get a very sturdy breaker bar and a very very long poll and spray some WD-40 or Knock er' Loose(similar to WD-40 but better) on the nut and use some brute force on it..
Good luck
Good luck
Pb blaster and the breaker bar is the way to go.
You are also going to have to have the hub pressed out to get the new studs in, which may mean that you will also need a new bearing.
HCivExoo
Mar 19, 2005 09:05 PM
