1989 Civic Brake lights not working...is there a switch near the brake pedal?
I checked all three bulbs ( rear wondow brake light and the two in the back ) and the fuses, everything is OK. When I hit the pedal, the lights don't come on. So I am not sure what to do next...I dread taking it to a mechanic for this.
I have heard it could be a mecahnical switch that is triggered by the brake pedal, or it could be a hydraulic switch.
Can anyone help me with this. Does this sound like a switch probelm? Where is it located?
Any help would be beyond helpful. I have looked around under the dash by the pedal but don't see anything.
Well, that is where the switch is located but I cannot for the life of disconnect the 2-P connector from thebrake switch. Access is horrible, I can just barely get a grip on the connector, and it does not want to pull straight off. Is there a clip or something to push?
I saw breaks in the insulation on the 4 wires going into the P-2 that exposed the wire inside. I separated them so they were not touching and checked but nothing lit up.
I am thinking I have to take it into the shop unless I am missing something obvious.
thanks very much for the diagram jlicrx
yes on the one side of the wiring there is a clip you push in.. Then it will pull straight off, then just jump the switch with a piece of wire, and if the lights work, your switch was bad..
Make sure your horn/stop fuse in the underhood fuse box is good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex »</TD></TR><TR><TD CLASS="quote">
Make sure your horn/stop fuse in the underhood fuse box is good.</TD></TR></TABLE>
check that fuse!
check that fuse!
Hey bud, are you able to provide a picture where yours is located? I cant seem to find mine. Im starting to think i dont even have one!
I don't think he's going to respond.
You replied to a thread that hasn't had any activity since 2006.
If you need help, it is totally acceptable and HIGHLY RECOMMENDED that you start a new thread rather than posting to old ones.
f@sth@tch89
Honda Civic (2001 - 2005)
Oct 1, 2012 09:03 PM
91efbluehatch
Jan 30, 2011 12:56 PM
EG6DGK
Nov 23, 2008 07:05 PM
