No Clutch, Stays on Floor
Old Jun 14, 2006 | 05:16 AM
majinx4's Avatar
Default No Clutch, Stays on Floor
So i was going out of town and when i took the wrong exit i made a U turn and after i got going my clutch just goes out. After further inspection i see my clutch slave cylinder dangling leaking fuild, it doesn't move at all. Is this slave cylinder the problem or could it be my release bearing or fork?
Old Jun 14, 2006 | 06:41 AM
JimBlake's Avatar
Default Re: No Clutch, Stays on Floor (majinx4)
Could be either one; take it apart & look.
If the slave simply came loose & fell off, you would have blown the piston out of it by pressing the clutch pedal.
Old Jun 14, 2006 | 07:54 AM
boostin92hatch's Avatar
mine did the same thing, when i took it all apart it was just the slave cylinder. so i would check there first, its an easy fix
Old Jun 15, 2006 | 11:30 AM
Hyaboosta's Avatar
Default Re: (boostin92hatch)
Happened to me. broke the slave and clutch fell. just swap it and bleed it. Call it a day
skhell
Transmission & Drivetrain
Jun 23, 2010 12:11 AM
b16a4
Nov 18, 2006 11:04 AM
s1ngle
13
Sep 21, 2005 12:01 PM
SikofFalln
Apr 25, 2003 02:49 PM
illusion
Mar 8, 2003 12:59 PM
