extended wheel studs
My car breaks a lot!
so i got the back studs on but we cant figure out how to install the fronts..its a 99 civic si
if you have them please help!
of give me a name of a shop in Northern California
thanks 4 your time!
thanks 4 your time!
u don't have to per-se, but it's good to, usually when u change out the studs the car isn't new....iono, it's just one of those things, u change one thing, while ur down there, it's good to do the other as well
I did ARP studs and when I pressed the hub from the knuckle, the bearing came apart, so replacing it is just something to have to do.
I did this without replacing the bearing (like the write up showed) and the car hummed a little on the highway. I'm guessing it was from the spot where the press forced the bearing ***** over the race and made a tiny deformation in the race or ***** or both.
ef90b16
Nov 28, 2008 09:36 PM
SomeGoodBud2
Suspension & Brakes
Mar 18, 2007 02:48 PM
