which would be a better ecu too use when using hondata s300
Old Jun 13, 2006 | 06:25 PM
EK9 ls vtec's Avatar
Default which would be a better ecu too use when using hondata s300
a p72 or a p28
Old Jun 13, 2006 | 06:43 PM
MR_Ek4's Avatar
Default Re: which would be a better ecu too use when using hondata s300 (EK9 ls vtec)
p28 FTW
Old Jun 13, 2006 | 07:09 PM
USDM-EK4*'s Avatar
Default Re: which would be a better ecu too use when using hondata s300 (EM1_00MRBuilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1_00MRBuilt &raquo;</TD></TR><TR><TD CLASS="quote">p28 FTW</TD></TR></TABLE>
i see that a lot of people used the p28 ecu for there setups. But isn't a p28 a sohc vtec ecu. Can someone tell why they use the p28 for a Bseries.
Old Jun 14, 2006 | 06:53 AM
racerx023's Avatar
Im using a P72 with S300 and having no problems the best upgrade I made yet.
Old Jun 14, 2006 | 07:15 AM
Natural Aspirations's Avatar
With the P72 you have more configurable outputs available. Knock sensor and the IAB are 2 things the P28 does not support. With the s300 you can use the IAB control for Nitrous control, Boost control, water injection or anything you would like.
Old Jul 15, 2006 | 10:02 AM
teddy_dc2's Avatar
i had a similar question, going to run s300 for gsr turbo set up but i see most people running a p28, that iab thing, isn't that the vac box in back of gsr mani? i was told i don't need it. so p28 or p72??
Old Jul 15, 2006 | 01:36 PM
98vtec's Avatar
moderator emeritus
Default Re: which would be a better ecu too use when using hondata s300 (USDM-EH2*)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM-EH2* &raquo;</TD></TR><TR><TD CLASS="quote">i see that a lot of people used the p28 ecu for there setups. But isn't a p28 a sohc vtec ecu. Can someone tell why they use the p28 for a Bseries.</TD></TR></TABLE>
doesnt matter once you have the correct map for the motor.
Old Jul 15, 2006 | 04:08 PM
j spec's Avatar
Default Re: which would be a better ecu too use when using hondata s300 (98vtec)
im running my s300 in a p05 i really don't think it matters which ecu you use
Old Jul 15, 2006 | 08:28 PM
zCivic's Avatar
Default Re: which would be a better ecu too use when using hondata s300 (roma's GSReg6)
P05,P06 and P28 are the same family add or remove a few parts to make any of them. P75's and P72 are the same way... Everyone knows hondas are pretty good on interchangeability, for OBD1 at least. I'm using a P06 and CROME for my ls-vtec, also you can control IAB's with P05,P06 and P28's if you add/remove a few parts there's directions on forum.pgmfi.org
elmejor
21
Aug 14, 2008 07:05 PM
MOVE OVER
Sep 6, 2007 08:59 AM
.I.Need.Money.
Aug 4, 2006 12:42 AM
B2FiNiTY
May 5, 2005 04:33 AM
VDoP-B18C1
Jul 12, 2004 03:55 PM
