Integra front brake swap only on my CX hybrid...will it be good enough?
Old Apr 16, 2002 | 09:52 AM
Yellow Dragon's Avatar
Default Integra front brake swap only on my CX hybrid...will it be good enough?
I'm thinking of just replacing my front brakes for now to Integra rotors/calipers. How much will they help out? I mean, compared to doing the full front/rear Integra brakes swap. Most of the braking done is from the front anyway.
-Todd
Old Apr 16, 2002 | 09:54 AM
Charles B.'s Avatar
Default Re: Integra front brake swap only on my CX hybrid...will it be good enough? (Todd C)
I did the front and the rears. Fronts should probably be good enough though.
Old Apr 16, 2002 | 10:10 AM
Default Re: Integra front brake swap only on my CX hybrid...will it be good enough? (SuperDuperEG)
Thanks.
Old Apr 16, 2002 | 10:58 AM
Katman's Avatar
-Todd
yeah the front GSR brakes are pretty good over the civic brakes. I suggest you upgrade the master cylinder and booster to GSR spec as well for almost optimum braking performance. If you'd run the rear GSR brakes then you'd have 100% optimum braking performance
Old Apr 16, 2002 | 04:38 PM
Katman's Avatar
Default Re: Integra front brake swap only on my CX hybrid...will it be good enough? (C5_ALLMOTOR)
i did the gsr front swap, but i kept the cx booster qnd cylinder, it works good, do i need to change them, i hear they are the same?
I suggest you do it for better braking power, but you don't have to. Its up to you.
Old Apr 16, 2002 | 07:20 PM
ineedboostbad's Avatar
I did the front and rear gsr swap on my 97 cx but the brake balance is all messed up, too much braking from the front... Understeer is a bitch! is it the gsr master cylender or or booster or what that controlls frnt to rear balance??
Old Apr 16, 2002 | 08:19 PM
Charles B.'s Avatar
Default Re: Integra front brake swap only on my CX hybrid...will it be good enough? (LShbVTEC)
prop valve controls the balance. get a 40/40 prop valve, AND the booster AND the master cylinder. HTH
Old Apr 16, 2002 | 08:56 PM
Thanks will do..
what master cylendar will match up with my hard lines??? I dont want to kink them trying to bend them?. and would junk yard stuff be ok or should I get it from honda??
Old Apr 16, 2002 | 09:06 PM
Katman's Avatar
Thanks will do..
well it depends. if you get a MC/booster from a GSR with abs, then you'll have to do a little bending, cut and flare...it's no big deal though. Little work done for better braking power.
Old Apr 16, 2002 | 09:18 PM
Default Re: Integra front brake swap only on my CX hybrid...will it be good enough? (Katman)
According to local Honda dealership, all civic proportioining valves are the same... I guess i'll get the gsr one... is ther a MC that will bolt righ up?
Also, what Rotors and pads would you reccomend upgrading to?
[Modified by LShbVTEC, 11:02 PM 4/17/2002]
EKkeen
10
Aug 28, 2012 05:49 AM
streethondar
Jan 13, 2011 05:49 AM
t57b18
Dec 4, 2005 07:14 AM
98silverhatch
11
Sep 26, 2002 05:14 AM
Yellow Dragon
Apr 16, 2002 10:19 AM
