b18b swap questions
Old Jun 13, 2006 | 05:34 PM
hatchydude's Avatar
Default b18b swap questions
if all goes to plan, im swappin the b18b in the hatch this weekend. but my quetion is, can i reuse my hoses like radiator, fuel return, fuel filter from the civic?
Old Jun 13, 2006 | 05:43 PM
CBEengineering's Avatar
Default Re: b18b swap questions (hatchydude)
yes
Old Jun 13, 2006 | 05:53 PM
Syndacate's Avatar
yeah, but if they look old and whethered, u still might wanna think about replacing 'em :-\
Old Jun 13, 2006 | 06:11 PM
leeminho86's Avatar
Default Re: (Syndacate)
Are you guys sure? I have a b18b in my car and had to replace the upper radiator hose, I bought it for the civic rather integra and it didn't fit(way too small). So I had to go buy the hose for the b18b engine.
Old Jun 13, 2006 | 06:12 PM
VRD^sam's Avatar
Default Re: (leeminho86)
you have to use b-series radiator hose(top and bottom)...the Civic ones are to small..
Old Jun 13, 2006 | 06:13 PM
hotlileg6's Avatar
I just did my swap into my hatch and I had to use the upper radiator hose off an Integra, you will probably have to trim it a bit
Old Jun 13, 2006 | 06:57 PM
hatchydude's Avatar
Default Re: (hotlileg6)
ok..so i need top and bottom radiator hoses from an integra. anymore i should worry about?
Old Jun 13, 2006 | 09:26 PM
hatchydude's Avatar
Default Re: (hatchydude)
anyone?
Old Jun 14, 2006 | 01:21 PM
hatchydude's Avatar
cool
Old Jun 14, 2006 | 01:27 PM
delus1on's Avatar
I encountered a problem once with the map sensor, for some reason I had two. If that happens to you make sure you plug the right one in.
Old Jun 14, 2006 | 10:01 PM
hatchydude's Avatar
Default Re: (delus1on)
thanx guys
Old Jun 14, 2006 | 11:05 PM
siblue_gzer's Avatar
both radiator hoses will need to be changed...
what kinda car do u have? ek or eg? cause i just did a b18b swap into my ek hatch..if u need help just holla
Old Jun 15, 2006 | 10:14 AM
hatchydude's Avatar
Default Re: (siblue_gzer)
its a eg. it will be my first swap so if anything, ill ask you guys for help.
Old Jun 15, 2006 | 12:18 PM
schardbody's Avatar
if you are keeping the EG radiator get del sol vtec hoses, the upper will needed trimmed a little still, but it fits good.
xxilah7861
Mar 7, 2015 07:16 AM
Lord Milferdeen
10
Nov 13, 2007 12:32 AM
prjctwhteg
Nov 10, 2006 11:46 AM
89Si
Jul 9, 2003 06:12 AM
Superhatch
Apr 8, 2002 06:25 AM
