b/m FPR
just installed my command-flo and am a little disturbed by a couple things
1 - are these really sensitive when you adjust - it went from 20-100 just from a slight turn
2 - for some reason i thought the system should retain pressure even though the car is off , mine goes instantly to zero
3 - i adjusted mine at idle , 46 psi , tightened the nut down , dorve around for a bit
got home to pop the hood and 56 psi
anyone have any insight on these problems , I hope i installed it right but i have like a hundred stock fpr's here so i can redo it if needed
I measured down 1/4" from the top and that was a little too low cause it cut the pin off the the bolt sits on , so I cut another one put it together and it seems fine except for these little probs.
Thanks - Jamie
Thanks - Jamie
The system does not retain pressure with the car off. Can't answer your other two questions - hope someone else can because I was thinking of getting one of these after making a few more mods.
"1 - are these really sensitive when you adjust - it went from 20-100 just from a slight turn"
I have to turn mine a half a turn to move it 2psi
"2 - for some reason i thought the system should retain pressure even though the car is off , mine goes instantly to zero"
Mine takes a while after the car's off to die down
" i adjusted mine at idle , 46 psi , tightened the nut down , drove around for a bit
got home to pop the hood and 56 psi"
That's fucked up
That's fucked up
thats what i thought , ok i didnt know how sensitive these things were
half a turn two psi , sounds right ------- i'm going to take a closer look tonight
thanks - Jamie
thanks - Jamie
My FPR needle drops very slowly once I turn the engine off. Did you install it correctly? Might want to dismantle it and check it out, hope you didn't use too much locktite on those bolts.
KevinEF7
May 18, 2013 05:03 AM
