no vtec,oil light stays on dash
Old Jun 12, 2006 | 06:50 PM
roc's Avatar
roc
Default no vtec,oil light stays on dash
motor has less than 30k.oil is up to level,just replaced the oil pressure switch with an oem one,same problem.any one have any suggestions.
Old Jun 12, 2006 | 07:21 PM
nholmes's Avatar
vtec solenoid?
Old Jun 12, 2006 | 08:25 PM
roc's Avatar
roc
Default Re: (nholmes)
not getting power to solenoid,i tried using my itr ecu,tried using a stepdown harness with an obd1 p72.same thing oil light stays on dash and no vtec
Old Jun 12, 2006 | 08:28 PM
225DC2's Avatar
Default Re: no vtec,oil light stays on dash (roc)
i had the same problem. drop the oil pan and check the oil pickup. when i did this to my car, i found a crap load of chipped bearings clogging up the pickup.
Old Jun 12, 2006 | 09:56 PM
Mike K's Avatar
Default Re: no vtec,oil light stays on dash (225DC2)
that, or the oil pump is bad. check it all out.
Old Jun 12, 2006 | 10:03 PM
MilFhunter001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nholmes &raquo;</TD></TR><TR><TD CLASS="quote">vtec solenoid?</TD></TR></TABLE>
My thoughts exactly..
Old Jun 13, 2006 | 03:42 AM
zc911's Avatar
Default Re: (hondabitch)
you could have dented the pan right at the pickup. happened on my prelude. won;t suck up enough oil.
Old Jun 13, 2006 | 04:35 AM
DontBlink's Avatar
Default Re: (zc911)
if the oil light is on would check your oil pump, it might have broke/shattered. if you drop the pan obviously look for metal flakes. but drop the pick up and look in there for chunks. i personally seen a few shattered due to non dampened crank pully's and one go bad to a sand blasted valve cover that still had sand in it that made its way to the oil pump.
Old Jun 13, 2006 | 09:37 AM
Circuit Star-29's Avatar
Default Re: (DontBlink)
Ouch...bearings come to mind...
insidiouseg-6
24
Jan 20, 2008 10:06 AM
1999blownlsturbo
Dec 15, 2006 10:32 PM
Cashflo
Sep 26, 2006 01:47 PM
ultra efro
Oct 25, 2003 06:01 PM
Cashflo
Aug 24, 2003 07:31 PM
