gsr brake swap question?
Old Jun 12, 2006 | 06:50 PM
o5mar1's Avatar
Default gsr brake swap question?
i bought gsr front spindles, and rear trailing arms i will be installing them next week, i need to know if when i install the 94-01 gsr booster and master cylinder( all this is going into a 93 vx hatch). My question is will my brake lines bolt up to the gsr master cylinder or do they have to be re-flared? i already searched and found information on the porportioning valve.
Old Jun 12, 2006 | 06:54 PM
Simple's Avatar
Default Re: gsr brake swap question? (o5mar1)
depends on if you got an abs MC or not. I personally have an ABS MC from a GSR and i had to cut and re-flare, as well as find a hard to get fitting. but it all worked out... why dont you take your GSR MC out to your car and just look at it side by side.... that'd tell you right away
Old Jun 12, 2006 | 06:57 PM
o5mar1's Avatar
i dont have the master with me i will be picking it up this weekend, im asking this because my friend is telling me to use the 91 dx master cylinder and that it bolts up to my current brake booster.
Old Jun 12, 2006 | 07:01 PM
Schrader's Avatar
Use the 91 EX Master cylinder, which bolts up to the original Civic Booster, and Brake Lines of your Civic.
Old Jun 12, 2006 | 07:05 PM
o5mar1's Avatar
thanks for the response
MistahJuice
Suspension & Brakes
May 10, 2015 09:18 PM
fongph
Jun 16, 2006 06:05 PM
ahbongkadah
Jul 5, 2005 04:44 PM
EJ2_B16
Aug 20, 2004 02:34 PM
JKim0901
May 30, 2004 08:27 PM
