d15b swap info pls.
my car. its 92 vx with d15 tranny from hmo.(bought it from h-t member) now i would like to swap the jdm d15b engine on it and add some bolt ons. now everything seems to be perfect coz i got the tranny. the problem is the wirings.. i duno how to wire is ders some place where i can get the wiring harness for this swap? pls help tnx
all you have to do is convert the 5wire o2 sensor plug to 4wire, you follow the directions from putting a gsr swap into a vx.
ignore the butterfly valves in the gsr intake manifold
(skip that wiring step)
most bolt ons are called bolt ons for their easy install. so don't stress over this stuff now
(skip that wiring step)most bolt ons are called bolt ons for their easy install. so don't stress over this stuff now
i did this swap in my VX. I love it to death. The install was easy, the O2 sensor was the only thing i had to mess with. Other then that, car started on the first crank'
if you're the one who bought that transmission from me... (95% sure it's you)
i have a NEW HONDA/OEM water pump and timing belt you can have also. come pick it up. don't toss in the engine yet bro. 213.215.9865 -david
