92 civic lx swap problem
Old Jun 12, 2006 | 04:10 PM
924drcivic's Avatar
Default 92 civic lx swap problem
I have a 92 4dr civic. just got done putting in a D15B. But it is not completed. i have 2 codes. An idle air control and a MAP sensor. I changed to the P28 ecu. my old map sensor connector still has power to it yet the new one doesn't. i was wondering if the 3 wires for the map sensor going to the ecu are the same wires from the old ecu to the new P28, or will i have to switch them between the connectors on the D connector. hopefully someone can help. haven't got to drive it lately and i need my fix.
Old Jun 12, 2006 | 04:17 PM
suckawillis's Avatar
Default Re: 92 civic lx swap problem (924drcivic)
wires are same. make sure you dont have the tps and map sensor plugs switched, common mistake
Old Jun 13, 2006 | 12:29 PM
924drcivic's Avatar
Default Re: 92 civic lx swap problem (suckawillis)
checked that and they wheren't swithed. i guess i just have alot of tracing to do. i just don't understand why my old map sensor still has voltage going to and my new one doesn't. i'll check that out tommorrow on my day off and keep you informed. keep postin.
Old Jun 13, 2006 | 02:10 PM
so you are using what harness??
Old Jun 13, 2006 | 02:16 PM
FalkenSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suckawillis &raquo;</TD></TR><TR><TD CLASS="quote">so you are using what harness??</TD></TR></TABLE>
Maybe the plugs in the new harness are shot.
Old Jun 13, 2006 | 02:18 PM
Default Re: 92 civic lx swap problem (fast95eg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 &raquo;</TD></TR><TR><TD CLASS="quote">Maybe the plugs in the new harness are shot.</TD></TR></TABLE>
thats what I was thinking... or a bad connection in the harness...
yugisxrc
Jan 21, 2013 10:46 AM
dan617
Dec 23, 2008 10:51 PM
ImprtRcr02
Feb 26, 2004 06:34 PM
