b16 idle woes
Old Jun 12, 2006 | 03:44 PM
Pure Sol's Avatar
Default b16 idle woes
Alright so Ive searched throughout the acrhives and found every possible solution to the idle surge problem, but none have fixed my particular case.
1. cleaned the IACV/EACV, no luck so i bought a new one straight from Honda.
2. cleaned the FITV, tested with another from a D16
3. Adjusted base idle to spec, following Honda guidelines
4. cleaned throttle body plate,idle adjust screw, IACV/EACV ports
5. checked for vaccuum leaks, with propane and brake clean
5. checked and cleaned all ground locations
If there is anything I've missed or could elaborate on please let me know. Any suggestions or hints that could lead me to solve this annoying case would be appreciated.
Old Jun 12, 2006 | 05:10 PM
EKBOOSTDREAMS's Avatar
Default Re: b16 idle woes (Pure Sol)
I had the same problem on my B16a bought new parts and all, still surged. It could be a TPS problem/needs calibrated, but what worked for me was that I pulled my ecu tried a new one and it did the same thing, but when I put my original ecu back in it went away. Try that or the TPS, hope this helps.
Old Jun 12, 2006 | 05:18 PM
Pure Sol's Avatar
Default Re: b16 idle woes (SIRTIM96)
ive tried just about everything i could think of so this one is new to me. TPS hasn't been touched at all but ill check that out as well. Thanks for the help, and any other suggestions are welcome.
Old Jun 12, 2006 | 05:24 PM
Xgen's Avatar
What year B16 and what OBD are you running, reason I ask is today I had a similar problem, what happened was,
Since I have an OBD0 B16 running OBD1 in my EJ, the intake manifold has that thing coming out of the front of it, small line goes to a vac source, big line goes to IACV, OBD1 cars dont have this wierd mechanism, anyway, what I did is perminetly disabled it and tied off the big line coming from the IACV, as for the mechanism, I made a gasket that blocks it off from sucking in air to the IM.
This solved my idle problem.
Old Jun 12, 2006 | 05:52 PM
allmotorsi04's Avatar
Default Re: (Xgen)
i know this sounds dumb but check your cruise control vacumn line and make sure its on the back of the intake manifold, and also go down the line and make sure there are no gashes in it......
Old Jun 13, 2006 | 10:18 AM
Pure Sol's Avatar
Default Re: (allmotorsi04)
Motor is a 95 B16A3 OBD1 with a P30. Ill look into that cruise control situation, but i don't think i have a vac line for that. Thanks to all that have contributed, more suggestions are welcome. Also anybody have a diag checklist from Alldata or any of the other computer programs?
Modified by Pure Sol at 2:43 PM 6/13/2006
Old Jun 13, 2006 | 06:14 PM
Pure Sol's Avatar
Default Re: (Pure Sol)
Tried everything and still have the same idle. Thanks for all the help and keep 'em coming.
Old Jun 14, 2006 | 03:08 PM
Pure Sol's Avatar
bump for help
Old Jun 15, 2006 | 02:33 PM
Try going to a good honda mechanic and getting your TPS sensor callobrated, if no luck after that have them put it on a PGM to check and see if theres any abnormal readings on any of the sensors. Hope this will help
Old Jun 15, 2006 | 03:29 PM
Blue_es_ai's Avatar
well i just to have the same problem,i do pretty much everithing that u did already n didn't work, but,i start using 93 octane fuel insted that 89 n stop doing it!
i got a b16a2 n im not saying that was the fuel but thats my history! hope u got it fix soon!!
Old Jun 15, 2006 | 05:35 PM
nello a.'s Avatar
have you done anthing to it recently?
Old Jun 21, 2006 | 08:14 AM
Pure Sol's Avatar
Default Re: (nello a.)
sorry its been so long, with work and all just a hassle tryin to get on. haven't done anything new to the motor or car since i did the swap. always use 93 octane in it and never run any octane booster or anything of that nature. After pulling most of my hair out trying to diag the problem i went through each vacuum line i could find to check for pinholes with no luck. Interestingly enough if i pull a line off the manifold the car starts to fluctuate idle faster than it does before. As far as the TPS it has never been touched, but I will still check that tip out. Thanks to all those who have helped and i will keep updated.
Old Jun 21, 2006 | 08:17 AM
BlownSihatch's Avatar
my car did this as well on my B16a, turned out my ecu had been chipped wrong, and was flashing a code saying that the automatic tranny was being goofy, i had it rechipped, and it idled fine
Old Jun 21, 2006 | 09:38 AM
Pure Sol's Avatar
Default Re: (BlownSihatch)
virgin usdm p30 ecu never touched, never opened. wish it could be that simple.
Old Jun 24, 2006 | 03:44 PM
Pure Sol's Avatar
paper clipped the diag connector just to check and got an all clear. noticed it seemed to idle fine until i get on it a little bit. anyone out there think of anything new?
Old Jun 24, 2006 | 04:00 PM
forcefedferio's Avatar
i have the same problem in my 92 LX...b16a3...virgin p30 surged like a mother ****** then i switched to an JDM b16 throttle body that uses the remotely mounted MAP and now it idles fine but i still throw and IACV code and MAP code and now a VTEC pressure switch code (wtf? never had this code before and VTEC works perfectly) but now my car stalls out while coming to a stop...i've adjusted my idle and tried to clean my IACV but maybe i just dont know how? how did you clean yours out? i used throttle body cleaner and then blew it out with air and let it dry. hopefully someone can pry themselves away from the "how low can i possibly make my civic" threads and "can i put a d-series tranny on a b18?" threads to help us!
andyc_0652
Oct 18, 2010 11:37 AM
jdmstyleg
Oct 15, 2009 06:55 PM
crxfreak1117
Sep 8, 2007 07:05 PM
mikeunreal2
Mar 29, 2006 09:27 PM
B16CRXT
May 6, 2004 07:46 PM
