thinner headgasket ( 2 layer)
Old Jun 12, 2006 | 02:24 PM
postman's Avatar
Default thinner headgasket ( 2 layer)
how does this ^^ affect piston to valve clearance. specifically on a b16. has anyone ever had an issue with this. Also related to same question. with the headgasket and aftermarket cams has anyone had a problem
Old Jun 12, 2006 | 02:48 PM
JDMlyfestyle's Avatar
Default Re: thinner headgasket (postman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman &raquo;</TD></TR><TR><TD CLASS="quote">how does this ^^ affect piston to valve clearance. specifically on a b16. has anyone ever had an issue with this. Also related to same question. with the headgasket and aftermarket cams has anyone had a problem</TD></TR></TABLE>
well a Thinner Headgasket means that the Head Is now Closer to the Block. If u have an aggressive Cam or just have some adjusted cam gears there could be Piston to valve contact
Old Jun 12, 2006 | 03:49 PM
postman's Avatar
Default Re: thinner headgasket (JDMlyfestyle)
yeah. i understand that. jus was wondering if anyone ever had ani issue on there honda. looking to do a mild port job, thinner gasket and a mild valvetrain. something decent but not a damn race car.
Old Jun 12, 2006 | 03:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman &raquo;</TD></TR><TR><TD CLASS="quote">yeah. i understand that. jus was wondering if anyone ever had ani issue on there honda. looking to do a mild port job, thinner gasket and a mild valvetrain. something decent but not a damn race car.</TD></TR></TABLE>
well when you start to finish your build off.. best thing that you can do is clay the motor to be sure that you have good V2P clearance
Old Jun 12, 2006 | 04:10 PM
postman's Avatar
how would you clay for vtec engagement. would you need to lock the rockers
Old Jun 12, 2006 | 04:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman &raquo;</TD></TR><TR><TD CLASS="quote">how would you clay for vtec engagement. would you need to lock the rockers</TD></TR></TABLE>
that is correct.. lock the rocker arms together and use some modeling clay
Old Jun 12, 2006 | 05:28 PM
postman's Avatar
is there a proper way to lock them
Old Jun 12, 2006 | 05:36 PM
http://www.c-speedracing.com/h...y.php
Old Jun 12, 2006 | 05:58 PM
postman's Avatar
good looking
Old Jun 12, 2006 | 06:50 PM
UncleD's Avatar
I run the RM M22x(12.1 lift) in my B16b with a Spoon H/G, no problems.
Ac01031234
Engine Machining & Assembly
Nov 20, 2016 11:36 AM
JDMEMone
Sep 7, 2010 07:47 PM
sivikvtec
Aug 31, 2006 10:17 AM
HamiltonRex
Mar 2, 2006 06:28 PM
Irishweird00
May 22, 2004 08:26 AM
