Spoon Clutch Metal Disc (3 Puck)
Old Jun 12, 2006 | 10:55 AM
digitalVinyl's Avatar
Default Spoon Clutch Metal Disc (3 Puck)
Anyone know how this clutch is for daily driving? I've heard mixed reviews, one one side it's similar to stock, the other side saying it's similar to an "off/on" switch and is for racing only....
Old Jun 12, 2006 | 11:05 AM
RagingAngel's Avatar
Default Re: Spoon Clutch Metal Disc (digitalVinyl)
I've driven on it and it can be a bit difficult to get used to at first.
Spoon's 3 puck disc should be the thicker version and will be more durable than the thinner Exedy model.
Slipping is what kills 3 puck clutches fast (slipping = stop/go traffic)
Don't expect it to last as long as a stock full face clutch, but your syncros will be happier with the lighter disc and the instantaneous engagement when driving at full song is very nice.
Old Jun 12, 2006 | 02:13 PM
Default Re: Spoon Clutch Metal Disc (RagingAngel)
Perfect, everything I needed to know, thanks.
Old Jun 13, 2006 | 12:50 PM
RE- v8killa121's Avatar
thats some good *** info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">
Slipping is what kills 3 puck clutches fast (slipping = stop/go traffic)</TD></TR></TABLE>question--
would the same be true for 6 puck clutches also?
Old Jun 13, 2006 | 08:09 PM
Default Re: Spoon Clutch Metal Disc (RE- v8killa121)
I can't say for certain since I've only test driven an ACT setup years ago with an Xtreme Pressure plate and solid 6 puck.
All I know is, it was a true bitch to drive. I suspect it was more due to the pressure plate.
I'd like the think the 6 puck is more resitant to wear than the 3 puck just based on the fact that there is more surface area vs. the 3 puck and you don't experience the sometimes violent judder/shudder of a 3 puck when you don't slip it enough off the line.
ALL IMPORT
Dec 26, 2006 07:23 PM
Dark_Teg
Jun 5, 2006 06:20 AM
BDTURBO
Nov 8, 2004 05:50 PM
TypeRuz
Oct 16, 2003 03:32 AM
done
Jul 21, 2003 10:59 AM
