piston to vavle clearance with ctr cams
Old Jun 12, 2006 | 09:22 AM
known's Avatar
Default piston to vavle clearance with ctr cams
I built a basically stock ls vtec with a b18b block and a gsr head, I would like to know if there is enough valve relief to put in ctr cams? anyone have exp. with this?
Thanks.
Old Jun 12, 2006 | 10:52 AM
known's Avatar
Default Re: piston to vavle clearance with ctr cams (vtecsir1)
bump for an answer
Old Jun 12, 2006 | 02:24 PM
known's Avatar
help
Old Jun 12, 2006 | 03:01 PM
.Radical_Edward.'s Avatar
Bounty - € 8,000,000
I'm not quite sure about that. I'm using ITR cams in mine and I was told that if I don't mess around with the cam timing too much, that I would be fine.
Old Jun 12, 2006 | 03:06 PM
known's Avatar
Default Re: piston to vavle clearance with ctr cams (.Radical_Edward.)
i was hoping for this. if i left the cams set at o,o they would be fine.
so you do have itr cams with this setup and you are ok then?
you have a stock block like me?
i have the oem head gasket, oem block and head unmilled.
thanks for the reply
Old Jun 12, 2006 | 03:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsir1 &raquo;</TD></TR><TR><TD CLASS="quote">i was hoping for this. if i left the cams set at o,o they would be fine.
thanks for the reply</TD></TR></TABLE>
If you want to find out how crazy you can get with the engine follow the link to C-Speed Racing in this thread https://honda-tech.com/zerothread/1657574
It will show you how to clay your engine to see how far advance/ retard you can go.
I'm using a stock B18A block and as far as advancing, I can only advance it a little bit, no where over 4 degrees, I think. It changes if you use VTEC pistons instead of the stock Non VTEC ones as the valve reliefs are much deeper.
Old Jun 12, 2006 | 03:49 PM
known's Avatar
right, yeah i cant really clay my motor now so..i just want to be sure before i throw in a ctr intake cam. i plan on leaving the cams on stock timing. so gsr exhaust side and ctr intake side.
b18c-1
Jun 14, 2006 12:55 PM
EJ8 GSR-T
Feb 20, 2006 09:42 PM
jdmek910
Nov 21, 2004 05:41 PM
Terrible One
Oct 23, 2004 06:26 PM
