Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
proper size for a turbo k24 with itr head
Old Jun 12, 2006 | 09:11 AM
rlx250's Avatar
Default proper size for a turbo k24 with itr head
what is the proper size turbo for a k24a1 with itr head.. only boosting 9psi.. looking to make around 350hp.. i want a quick spooling turbo.. for a daily driven ep..
Old Jun 12, 2006 | 09:14 AM
Newborn_'s Avatar
Grace Under Pressure
i'd recommend a look in the ep forum mate.
Old Jun 12, 2006 | 10:18 AM
toyomatt84's Avatar
Sanji
The K24 will be from an Accord, TSX, or CR-V. I would recommend something in the line for a T3/T4 hybrid. I've had good luck with those in the past on I-4's.
Old Jun 12, 2006 | 10:38 AM
Vantage's Avatar
id have to agree, a T3/T4 if your only going to 9psi, they are realatively cheap and work well.
Old Jun 12, 2006 | 12:02 PM
rlx250's Avatar
Default Re: (B18a_CRX)
i have k24a1 with itr head.. what trim should i get for t3/t4 hybrid??
Old Jun 12, 2006 | 03:31 PM
toyomatt84's Avatar
Sanji
I'd go with a 55-60 trim for the compressor housing, simply because it's a larger displacement engine (for I-4's). If you're talking about a D17, I'd go with a 50-55, for quicker spooling.
Old Jun 13, 2006 | 03:29 PM
rlx250's Avatar
Default Re: (toyomatt84)
im thinking about getting this..
precision turbo t3/t4
Max. Rated HP = 565
Part No. = SC-4431E
Wheel Dia. = 58mm
Wheel Inducer = 2.290"
Wheel Exducer = 2.950"
Wheel Trim = 60
T04E Inlet/Outlet = 3" / 2"
Bearing System = 360 Race
A/R Ratio = .48
Turbine Specs: Wheel Style = T31
Wheel Inducer = 2.559"
Wheel Exducer = 2.228
will this be perfect for my application.. i want a fast spooling turbo..
im just a noobie here soo be gentle.. hehehehehe..
i ust want to make sure i get the right turbo ..
only looking to make 350hp or more is possible..
9psi only
Old Jun 13, 2006 | 04:24 PM
toyomatt84's Avatar
Sanji
Will it work, yes. Will it spool quickly, yes and no. It's one of the largest possible Trims available for the T3/T4 hybrid, so for a T3/T4, it will spool the slowest. But, it will definitely yield higher pressures overall. But, since you're just searching for quick spooling, I would say no. I would say, maximize your Trim at 55, leaving a 52-53 as the ideal size.
Old Jun 14, 2006 | 01:53 AM
rlx250's Avatar
thanks toyo..
Old Jun 14, 2006 | 02:54 AM
toyomatt84's Avatar
Sanji
Not a problem.
antoni
Dec 25, 2010 07:17 AM
Monkey Z.
Nov 6, 2005 02:34 PM
delslow94
Jul 29, 2003 02:50 PM
UnderPressure
May 4, 2002 11:12 PM
