how can you clean bearings?
Old Jun 12, 2006 | 02:28 AM
TH22EK9's Avatar
Default how can you clean bearings?
i am putting a block together and stupidly got some dirty grease on some new bearings. since it's a bad idea to use brake cleaner on bearings, what could i use?
i was thinking about using some rubbing alcohol. any pros, please chime in.
Old Jun 12, 2006 | 10:58 PM
TH22EK9's Avatar
Default Re: how can you clean bearings? (TH22EK9)
someone help plz.
Old Jun 13, 2006 | 08:53 AM
IN VTEC's Avatar
Wipe the grease off with a paper towel.
Wash with Dish soap (ie: Palmolive), hot water, and a nylon dish washing brush or a soft dish rag that doesn't leave lint.
Blow dry with a blow gun.
Lube the back side with oil and install by sliding the bearing into the half. Lube the face of the bearing with assembly lube (ie: Torco) and install cap.
goat86
Apr 19, 2014 12:00 AM
dbsharp
May 30, 2010 02:46 PM
Master23
Apr 4, 2006 08:09 PM
92hatchattack
Jun 7, 2005 09:21 AM
pentaq
Feb 15, 2005 09:59 PM
