door ajustment
Old Jun 11, 2006 | 07:48 PM
hcivic99's Avatar
Default door ajustment
well to make a long story short i had my door open and backed in to a pole and bent the door back far enought to fu*k the fender up so i took that off and got the door to shut properly. but the only thing is i need to move the door towards the rear of the car like a 1/4 of a inch how should i go about doing that??
Old Jun 11, 2006 | 07:53 PM
DFW's Avatar
DFW
Default Re: door ajustment (hcivic99)
when i got new doors, it was just trial and error by loosing/retighting and moving the door till it was right. it's a bitch.
Old Jun 11, 2006 | 07:59 PM
JDM-EJ1's Avatar
Default Re: door ajustment (DFW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote">when i got new doors, it was just trial and error by loosing/retighting and moving the door till it was right. it's a bitch.</TD></TR></TABLE>
Sounds like this is the only way to do it.
Old Jun 11, 2006 | 09:13 PM
postman's Avatar
sounds more like you actually bent the hinge arms that hold the door on. if that happened. ou would need new omes to line it up correctly
Old Jun 12, 2006 | 08:17 AM
hcivic99's Avatar
Default Re: door ajustment (postman)
well i mean it shuts and locks and stuff there is just a tab bit big gap between the end of the door and the rear courter panel
Old Jun 12, 2006 | 09:11 AM
Elwuudz's Avatar
Default Re: door ajustment (JDM-EJ1)
BUMP.... trial n error
i suggest have 1 person help to expodite the process
Old Jun 12, 2006 | 09:39 AM
instructor74's Avatar
Default Re: door ajustment (Elwuudz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman &raquo;</TD></TR><TR><TD CLASS="quote">sounds more like you actually bent the hinge arms that hold the door on. if that happened. ou would need new omes to line it up correctly</TD></TR></TABLE>
You could also have twisted the A pillar a little bit the door might still close but I would have it checked by a good body shop. twisting the a pillar a little could cause water leaks around the door or the window
suhteevin
Jan 6, 2009 09:04 PM
raphael
Paint and Body
11
Nov 8, 2007 05:36 AM
tupark
13
Apr 25, 2004 03:27 AM
CB_ejcoupe
Jan 26, 2004 02:35 PM
98itR484
May 22, 2002 09:20 PM
