Eclipse stock turbo fit b16?
Old Jun 11, 2006 | 05:35 PM
civic_crazy02's Avatar
Default Eclipse stock turbo fit b16?
I was told that a stock turbo and injectors from a 92 eclipse awd turbo would fit my b16a2? I dont know how or if it will even work....just wondering if it would?
Old Jun 11, 2006 | 05:38 PM
JDMlyfestyle's Avatar
Yes the 14b turbo will work on a B16. you just have to buy a manifold that is flanged for the 14b.
The injectors can be used but you have to wire up a resistor box in order to run them
BTW search this topic has been beaten to death
Old Jun 11, 2006 | 06:43 PM
mugenpowered's Avatar
Default Re: Eclipse stock turbo fit b16? (civic_crazy02)
Don't expect to open your hood, bolt it on, and drive away with boost.
With time and money you can piece together a turbo kit that includes the eclipse turbo but after tuning, parts and labour you will be lucky if your bill is lower than $2500.
Old Jun 11, 2006 | 06:44 PM
Orangecivic251's Avatar
Default Re: Eclipse stock turbo fit b16? (mugenpowered)
Old Jun 11, 2006 | 06:54 PM
broketuner-Sol_Si's Avatar
Default Re: Eclipse stock turbo fit b16? (OrangeCiviC251)
Back before I decided to go NA I was told a the DSM turbos either 14b or t25 were both too small to get power out of a b16. But yes both of those cn work, but there will be some modification involved to get the injectors to work. just make sure with whatever you go with you immediatly get it to a good tuner.
Old Jun 11, 2006 | 06:56 PM
schardbody's Avatar
damn, i wish i knew the USD to CND conversion, thats sounds awefully high. the HMT route is easily attained for around $1000 USD
Old Jun 11, 2006 | 06:57 PM
Default Re: Eclipse stock turbo fit b16? (broketuner-egb16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by broketuner-egb16a &raquo;</TD></TR><TR><TD CLASS="quote">Back before I decided to go NA I was told a the DSM turbos either 14b or t25 were both too small to get power out of a b16. But yes both of those cn work, but there will be some modification involved to get the injectors to work. just make sure with whatever you go with you immediatly get it to a good tuner.</TD></TR></TABLE>
they are great for quick spool ups.. but they will definately run out of juice in the higher RPM's. you will have 15 psi at 7 or 8 but that little turbo is spinning soo fast its just a huge heat source.. you would see much better results with a T3/T4 setup with a .60 AR housing
jonezen1
Aug 16, 2006 10:59 AM
bluesihatch
Aug 14, 2006 11:35 AM
romoracing
Dec 23, 2004 04:49 AM
p0liX
Jan 11, 2003 02:04 PM
