what kind of gain is expected, if i change CTR piston in USDM ITR B18C5?
as topic, what kind of gain is expected, if i change CTR standard size or .25 oversize on a USDM B18c5?
Modified by Mugen_DC2R at 9:45 PM 6/26/2006
Don't do it.
They're heavy, have enormous domes, and will yield you an unnecessarily high CR.
Ditto.
CTR pistons are overhyped. You can make more power with less compression because the CTR piston has poor flame travel.
Opt for some JDM B16's if you want to stick Honda.
Or you can get some good pistons, IE: CP...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruben19 »</TD></TR><TR><TD CLASS="quote">true!!!</TD></TR></TABLE>
You will gain lots of detonation on pump gas. Trust me I have been down that road before
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tim_adams85 »</TD></TR><TR><TD CLASS="quote">Don't do it.
They're heavy, have enormous domes, and will yield you an unnecessarily high CR. </TD></TR></TABLE>
Well put.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR »</TD></TR><TR><TD CLASS="quote">Ditto.
Or you can get some good pistons, IE: CP...</TD></TR></TABLE>
P30's are the way to go.
Unless you want like 12.xx:1 c/r and have to pull a ****-ton of timing. There's a thread around here somewhere...
Well put.
Actually JDM P73's have alot better design and a little higher C/R than the P30's
The P73-00 has a flatter dome, but has a higher compression height than the P30
The P73 also has a thicker top ringland than a P30
Why would you want to downgrade to a P30? If your dont need to rebuild yor bottom end, milling you head is a better choice.
killerpenguin21
Jul 9, 2006 10:56 AM
