car is acting wierd.
Old Jun 11, 2006 | 02:54 PM
lemon_juice's Avatar
Default car is acting wierd.
my car wont hold a steady idle, running very rich and produces black smoke, and the gas mileage went down to about 15-20mpg.
this all happened after i installed my new intake manifold on my jdm d15b which i learned uses a different throttle body than the edelbrock manifold wants. im now using a tb off a d16z6 i had laying around the house so im thinking the problem may be either the TPS sensor or the MAP sensor which is attached to the tb rather than a hose to the firewall. i also did the coolant bypass that may have tricked the IACV but i dont see why that would make the car run very rich.
any ideas to whats going on with the car? oh yea, i also have an adjustable fuel pressure regulator that i dropped the PSI down to 20psi and the car was still running. before this problem the car would normally die around 30 psi and thats what is leading me to think its a sensor problem. i didnt find no leaks either.
Old Jun 11, 2006 | 02:56 PM
JDM-EJ1's Avatar
Default Re: car is acting wierd. (lemon_juice)
Are you getting any CELs?
Old Jun 11, 2006 | 02:58 PM
Default Re: car is acting wierd. (JDM-EJ1)
no CEL, and i havent gotten one for the entire 2weeks its been like this
Old Jun 11, 2006 | 03:59 PM
maybe if i route the coolant back through the IACV then something might help out ill do it soon but i still dont think the reason for the car running rich is because of this....well my intention of this was a bump!!
Old Jun 12, 2006 | 04:11 AM
bump
Old Jun 12, 2006 | 04:35 AM
hnp5's Avatar
try to plug another computer in...my friend had that problem and it was the ecu acting up....
Old Jun 12, 2006 | 07:08 AM
xsuperxsonx's Avatar
Default Re: car is acting wierd. (cuban0)
that is tru it could possibly be the ecu .,,,, if not then try adjusting the timing
Old Jun 12, 2006 | 07:12 AM
imadigitalgod's Avatar
Default Re: car is acting wierd. (xsuperxsonx)
make sure the amss airflow sensor is on the right way. i installed some subs on a friends car, then someone was helping me put everything back on(i had to take the MAF off to get to the firewall) except he put the MAF on backwords. it made the black smoke, no smooth idle...sounds like that might be it.
Old Jun 12, 2006 | 07:28 AM
purokogi's Avatar
wait... pho has msg in it!?
Old Jun 13, 2006 | 08:01 AM
Default Re: (purokogi)
is it fixed?
Old Jun 14, 2006 | 11:10 PM
Default Re: (imadigitalgod)
whats this AMSS airflow sensor? and MAF?? u mean the MAP sensor that needs vacuum from the throttle body? i cant think of a way that would be backwards because the plug faces the entry to the TB right?
im thinking its the TPS (throttle position sensor) because the TB im using was found im my garage and i needed it on the count my jdm one wouldnt let it idle and send it to 3000rpm no matter wat i did unless i plugged the bottom hole on the inside of the TB.
the ECU isnt the problem i swapped it with another stock one that i used to have and problem was still there.
Old Jun 15, 2006 | 12:26 AM
timing checked in fine, and i adjusted it both ways 2* with no change to the idle other than a slight help in calming the jumping around.
Old Jun 16, 2006 | 08:35 AM
Default Re: (lemon_juice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lemon_juice &raquo;</TD></TR><TR><TD CLASS="quote">whats this AMSS airflow sensor? and MAF?? u mean the MAP sensor that needs vacuum from the throttle body? i cant think of a way that would be backwards because the plug faces the entry to the TB right?
the ECU isnt the problem i swapped it with another stock one that i used to have and problem was still there.</TD></TR></TABLE>
crap sry i meant the Mass Airflow Sensor
Old Jun 16, 2006 | 02:00 PM
bumb
Old Jun 16, 2006 | 08:58 PM
bump
does this really sound like a bad TPS sensor? car also backfires wen the car is in gear and the engine is used to slow the car down.
Old Jun 16, 2006 | 09:10 PM
strictly.business's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imadigitalgod &raquo;</TD></TR><TR><TD CLASS="quote">crap sry i meant the Mass Airflow Sensor</TD></TR></TABLE>civics dont have mass air flow sensors.
Old Jun 16, 2006 | 09:11 PM
Banned
Default Re: (strictly.business)
its either your tps or bad plugs.
phorse
24
Dec 17, 2014 04:07 PM
kreatekustomz
Mar 1, 2010 02:12 PM
01 LudeDude
Feb 9, 2008 01:34 PM
jarredm
Nov 12, 2007 07:37 PM
