Need info about header and gsr swap!!
Old Apr 15, 2002 | 10:05 PM
civicRacer95SI's Avatar
Default Need info about header and gsr swap!!
I have a 95 si hatch and I put a gsr swap in, I am using stock header from a 94 gsr and the stock cat from my si. I had the B-pipe custom made to fill the gap, so now my b-pipe is longer than the stock 95 si one. My question is I want to get a aftermarket header but need to plug in my o2 sensor do i use the one from a 99 si? or the gsr I just need to have the o2 sensor before the cat. thanks
[Modified by civicRacer95SI, 7:21 AM 4/16/2002]
Old Apr 16, 2002 | 03:01 PM
LXguy's Avatar
Default Re: Need info about header and gsr swap!! (civicRacer95SI)
Use the sensor from the GSR.
Steve
Old Apr 17, 2002 | 08:24 PM
b19coupe's Avatar
Default Re: Need info about header and gsr swap!! (LXguy)
Integra Type-R header works for me in my EG. Type-R header is about 6 inches longer than the GSR. The GSR catalytic converter is longer than Type-R for some reason, that's why the GSR b-pipe is shorter. I was using the GSR header and a 6 inch pipe from a 93 LS to bridge the gap before.
athbaseball23
Jul 27, 2006 11:44 AM
redhondacivic
Jun 24, 2006 07:14 PM
kinvid22
Mar 6, 2004 11:58 PM
HOND PWR
Jun 18, 2002 07:49 PM
CivicEx95
May 2, 2002 01:52 PM
