Killed my h23....too much happy feet!!!!!!!!!
Old Jun 11, 2006 | 10:47 AM
mugenmarauder's Avatar
Default Killed my h23....too much happy feet!!!!!!!!!
I just had some extensive work done to my engine.....port polish....new dual valve springs...alluminum retainers......polished valves....cleaned pistons...port matched intake manifold.......well...it is all pretty much worthless now.......
I heard my mechanic say it needs a "breakin period"...do not run it hard for about a week then come back and valves adjusted.
Well I ran it hard being late for work....not valves are bent....I also think I punctured a piston.
here is the questions.....can I simply replace the valves...and the piston(if it is damaged)? Or do I have to send my head to the machine shop?
Old Jun 11, 2006 | 12:23 PM
DIRTYsouthBB6's Avatar
polished valves?
what makes you think that you punctured a piston?
Old Jun 11, 2006 | 12:54 PM
Default Re: (DIRTYsouthBB6)
Mind you have not seen it first hadn this what I got from the mechanic. My mechanic just polished the stock valves(keeps carbon off of them)
Old Jun 11, 2006 | 12:59 PM
Hawkze_2.3's Avatar
Default Re: (mugenmarauder)
A hard break in is actually highly reccomended for new engines to produce more power once it's done being broken in.
Old Jun 11, 2006 | 01:16 PM
Default Re: (Hawkze_2.3)
What do you mean a hard breakin...run it hard for a minute then let it "rest"?
Old Jun 11, 2006 | 01:25 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenmarauder &raquo;</TD></TR><TR><TD CLASS="quote">What do you mean a hard breakin...run it hard for a minute then let it "rest"?</TD></TR></TABLE>
Read up on this-----&gt;http://www.mototuneusa.com/break_in_secrets.htm
Old Jun 11, 2006 | 01:28 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Read up on this-----&gt;http://www.mototuneusa.com/break_in_secrets.htm </TD></TR></TABLE>
a very good article.
Old Jun 11, 2006 | 03:10 PM
Default Re: (98vtec)
Thanks but I really screwed up...I push it to 110...slowed down shortly afterwards but I did someone egging me on......anyway when the engine failure happened I was doing a steady pace of 70. Does anyone know if have to send it to the machine shop....or could just simply replce the valves.
Old Jun 11, 2006 | 03:12 PM
Ashes Devourer's Avatar
Default Re: Killed my h23....too much happy feet!!!!!!!!! (mugenmarauder)
lol
Old Jun 11, 2006 | 03:26 PM
plikit's Avatar
Default Re: Killed my h23....too much happy feet!!!!!!!!! (Ashes Devourer)
have your mechanic crack it open to see the extent of the damage first
Old Jun 11, 2006 | 06:32 PM
shutta's Avatar
wow dude, I can't even comprehend what you are trying to type.. take your time and use punctuation/grammar
Old Jun 11, 2006 | 06:36 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenmarauder &raquo;</TD></TR><TR><TD CLASS="quote"> Does anyone know if have to send it to the machine shop....or could just simply replce the valves.</TD></TR></TABLE>
No, no one knows because we don't have the engine here in front of us. You'll have to take it apart and actually try looking at it or have someone else look at it to see the extent of the damage. In your case, I'd take it to a machine shop for sure...
Old Jun 11, 2006 | 11:40 PM
Thanks...I think I will do that...rather be safe then sorry...besides gives me an excuse to buy new valves anyway(trying to look at the bright side). I will post some pictures though
Old Jun 12, 2006 | 07:00 AM
PrecisionH23a's Avatar
I don't necessarily agree with this 100%. I believe engines should be broken in the way that they are driven. If it's a race motor, then I can justify beating on it. That's how all of the big boys do it with their race engines.
If it's a daily driver then I recommend baby it for a while for 500-1000 miles. I've always done it this way and I've always had magnificent results.
Old Jun 12, 2006 | 11:34 AM
The_Sober's Avatar
Default Re: (PrecisionH23a)
I don't know which is funnier: the content of the posts, or the posts themselves...
Vtec04
Engine Machining & Assembly
Nov 10, 2017 02:23 PM
BuyImports2
Mar 2, 2006 11:32 AM
jdmjeff
Dec 21, 2005 02:18 PM
polishprinze
Jan 31, 2005 12:21 PM
RTW DC2R
Dec 21, 2004 07:11 PM
