Engine mount play...normal or not?
Old Jun 11, 2006 | 09:30 AM
Cee_mon's Avatar
Default Engine mount play...normal or not?
Should you be able to move the motor at all by rocking it back and forth with just your arms? I didnt notice any movement on the passenger side of the car, but on the drivers side upper mount I can move it acouple millimetres. I tightened the bolt on the upper driver mount, but it still has the play.
Is it normal or should it be rock solid?
Old Jun 11, 2006 | 09:31 AM
JDM B16A's Avatar
Default Re: Engine mount play...normal or not? (Cee_mon)
yea, same **** happen to my motor. It appeared my engine MOUNT was broken and thats y it move back and forth like that.
Old Jun 11, 2006 | 10:06 AM
Cee_mon's Avatar
Default Re: Engine mount play...normal or not? (JDM B16A)
Thanks ^
So Iam guessing its suppose to be solid?
Old Jun 11, 2006 | 10:27 AM
LL2009's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cee_mon &raquo;</TD></TR><TR><TD CLASS="quote">Thanks ^
So Iam guessing its suppose to be solid?</TD></TR></TABLE>
yes the motor is not suppose to moved. the more solid the better.
Old Jun 11, 2006 | 12:13 PM
JDM B16A's Avatar
Default Re: Engine mount play...normal or not? (LLEO245)
THE MORE SOLID IT IS THE BETTER. YOU DON'T WANT YOUR ENGINE FLOP'N AROUND WHILE YOUR BOUNCING UP AND DOWN DUE TO LOWERING YOUR CAR ON THE ROAD AND HAVE **** GOING LOOSE.
mkazm83
Feb 3, 2006 09:01 PM
Loveless
Aug 15, 2003 11:48 PM
CIVIX
Mar 18, 2002 06:03 AM
balistic CRX
Dec 27, 2001 04:37 AM
