Chipped ECU or No?
Old Jun 11, 2006 | 09:05 AM
honda_coupe's Avatar
Default Chipped ECU or No?
My buddy has a B16 SiR motor swap, and he was wondering if he needs to chip his ecu, or will a SAFC controller take care of that?
Old Jun 11, 2006 | 09:15 AM
JDM B16A's Avatar
Depending on what ECU he's working with. If its a stock P06 ( like in my case) den hell yea. You need to chip it for DOHC Vtec and if it was a manual u need to chip it for 5spd. If its a stock p72 den i guess you can leave it. Use the GSR PROGRAM.
Old Jun 11, 2006 | 09:27 AM
Default Re: (JDM B16A)
alright i will ask him, and let him know the advice.
Thanks!
Old Jun 11, 2006 | 09:50 AM
Syndacate's Avatar
Default Re: (honda_coupe)
in all reality I would just drop the stock ECU (whatever that is) in there if you're not going to upgrade it outside of I/H/E, but if you are going all out on it then u'll have to get a wider base map with variable adjustments (chipped or a prog) and have somebody tune it..
Old Jun 11, 2006 | 12:41 PM
Default Re: Chipped ECU or No? (honda_coupe)
he basically wants to know if the VAFC can do that? especially tune for turbo. the fuel that is boost controller BK 025: especially tune for turbo the fuel that is boost controller is seperate stand-alone ecu
Old Jun 11, 2006 | 01:20 PM
fmrprojects's Avatar
get a chipped ecu and tune with crome
2.0 civic
Jan 9, 2010 08:56 AM
hannslebo
Jul 10, 2009 11:28 AM
acuragsr101
Sep 6, 2007 08:50 AM
mtber
Mar 7, 2007 09:59 AM
89 civic si
Sep 24, 2006 10:34 AM
