zc won't fire up...can't figure out why
Old Jun 11, 2006 | 08:44 AM
scmil95eg's Avatar
Default zc won't fire up...can't figure out why
swapped a sohc zc in my 95 del sol to replace a tired d15b7. car still has the obd1 ecu and harness.
i swapped over all the obd1 sensors to the zc. had to use a obd0 map sensor from crx cuz zc throttle body didn't have map. as far as the other sensors are concerned, everything else should be the same as the d15. put in the d15 distributor and injectors. put new clutch in, put trans. on, engines in, everything's hooked up. double checked all the grounds (valve cover bolt, thermo. housing, & trans.) all good & tight.
tried to start it friday night - no spark. a friend hooked me up with a new i.c.m. and coil. put those in + 4 new plugs and new magnecor wires. tried to start it saturday - getting spark but only 1, sometimes 2 cylinders will fire.
i'm sure it's getting fuel cuz when i pull the plugs - they're wet. i can't think of anything else it could be in the ignition. i'm baffled. am i overlooking something stupid? could this just be a bum zc from hmotorsonline? i'm kinda out of ideas.
alx_90ef
Mar 23, 2010 07:51 PM
BoostinZc93
Nov 9, 2006 05:11 PM
scmil95eg
Jun 12, 2006 10:52 AM
SlippylesKB
18
May 2, 2004 11:39 PM
rpm9100
Dec 17, 2002 07:20 AM
