Anyone ever replace a radiator fan switch on a b16a?HELP,HELP!!!!!!
Old Jun 11, 2006 | 06:28 AM
a12rnulfo's Avatar
Default Anyone ever replace a radiator fan switch on a b16a?HELP,HELP!!!!!!
I was sitting in the drive thru at Mcdonalds on friday night and out of the blue my engine started to overheat. The temp. reached about a quater of an inch from the H on the gauge. I checked fans, relay and thermostat and they are A ok, so i'm leaning towards the fan switch. All i know is that the location of this switch should be around the same location of the knock sensor. Has anyone ever changed one or has a link that might be helpful? Please help!!!!!!!!!!
Old Jun 11, 2006 | 08:18 AM
a12rnulfo's Avatar
Default Re: Anyone ever replace a radiator fan switch on a b16a?HELP,HELP!!!!!! (a12rnulfo)
Another problem i notice is where to get the part? I went to Autozone and on the item number for the fan switch it has a note that say's "located next to thermostat housing". My is located in the back behine the block, will the one that Autozone sell's work for my or what's the dame deal????????
ANYONE, ANYONE OUT THERE??????????
Old Jun 11, 2006 | 10:54 AM
non-VTEC's Avatar
yes the fan swtich is located on the thermostat housing. there is a 2 pin connector/plug on it.
Old Jun 11, 2006 | 11:56 AM
a12rnulfo's Avatar
Default Re: Anyone ever replace a radiator fan switch on a b16a?HELP,HELP!!!!!! (non-VTEC)
I have a jdm 1st gen. non-obd b16a and there's nothin' that looks anything like you described by the thermostat housing. I think your talkin' about a b16a1 the
2nd gen and higher engine's!!!!!!!!
Old Jun 11, 2006 | 11:58 AM
hondakevin21's Avatar
Look on the head below the distributor.
tonysaur
Nov 17, 2007 11:39 AM
jry2598
Aug 24, 2006 11:09 PM
808MAUI
Feb 23, 2006 07:51 PM
JDM_Type-R
Jun 16, 2002 08:31 PM
