JDMB18C MISFIRES
Old Jun 10, 2006 | 07:15 PM
9WON4's Avatar
Default JDMB18C MISFIRES
b18c bone stock with obd-1 conversion misfires/hesitates/sputters at bit when I am CRUISING between 3000-5000 rpms. No problem at full throttle! I have done the following: distributor, cap, rotor, wires, plugs, ALL THE STUPID ****!!! HELP!!!! Why is this happening......I need b18c WIZARDS to reply!!! I HAVE ENDLESSLY SEARCHED THREADS FOREVER!!!
Old Jun 10, 2006 | 08:22 PM
project_delta's Avatar
Default Re: JDMB18C MISFIRES (kidkanedtx)
I would look at your fuel system, maybe a problem with the tps or something. Sounds like a part throttle fuel delivery problem to me. Only problems at part throttle? Everything is ok at idle? What ECU are you running?
Old Jun 10, 2006 | 08:29 PM
Luserkid's Avatar
Default Re: JDMB18C MISFIRES (project_delta)
My next thing would be timing.
Old Jun 11, 2006 | 07:45 AM
9WON4's Avatar
it sputters/stutters between these rpm, UNLESS i AM AT full TROTTLE.....100%.....the idle is a little off, but after the motor reaches Temp, the iacv does not function.........could a TPS be the problem here?.....I am hopefully going to get to my valve adjustment today.......hopefully that doesn some thing....thanks guys
Old Jun 11, 2006 | 07:47 AM
9WON4's Avatar
Default Re: JDMB18C MISFIRES (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">My next thing would be timing. </TD></TR></TABLE> I know my timing is near perfect....again BONE stock.....intake and exhaust.....the motor is JDM...using.p72 obd 1 ecu, and it already did this sputtering when i had the jdm obd-2 p72 installed.......so i know thats not the problem......
Old Jun 11, 2006 | 07:57 AM
littlegreenb18's Avatar
I'm thinking tps, its really easy to check the signal, and if you originally had a d series and you still have it, that tps SHOULD work as a replacement, mine did, and i'm pretty sure most are interchangable, but i wont say all because i'm just not sure. hope this helps
Old Jun 11, 2006 | 08:38 AM
JeffBro's Avatar
I dunno how handy you are with a multi meter but heres hows you can test the signal. Get a multi meter and find some sort of pin or something to back probe the connector. Take the positive lead and probe the middle wire on the 3 wire tps connector. Then connect the neg lead to a good ground on the motor. Turn the key on but don't start the engine. Your looking for a range of .500 Volts(throttle closed) to 4.5 volts(WOT). Good luck.
Old Jun 11, 2006 | 03:57 PM
9WON4's Avatar
Default Re: JDMB18C MISFIRES (littlegreenb18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littlegreenb18 &raquo;</TD></TR><TR><TD CLASS="quote">I'm thinking tps, its really easy to check the signal, and if you originally had a d series and you still have it, that tps SHOULD work as a replacement, mine did, and i'm pretty sure most are interchangable, but i wont say all because i'm just not sure. hope this helps </TD></TR></TABLE>
but the tps has to be drilled out to be removed, right?.....it is integrated with the throttlebodyunit
Old Jun 12, 2006 | 02:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidkanedtx &raquo;</TD></TR><TR><TD CLASS="quote">but the tps has to be drilled out to be removed, right?.....it is integrated with the throttlebodyunit</TD></TR></TABLE>
when i had problems with my b18c tps, i swapped on my d15 tps, it was the same part, but the d series had it rivited in, and my b18c was bolted on, so all i had to do was drill the heads off the rivits, took like a minute, and unbold the one of my b series, and bolt the d15 tps on, so the short is answer is yes, but its no biggie
Old Jun 12, 2006 | 07:23 PM
9WON4's Avatar
do you think the valves could be causing this problem?....the motor has got to be around 60,000 miles now and i have never done an adjustment on the valves......its just that they are so quiet still, i didnt think they needed adjusting....then again.....i beat the everliving **** out of this motor EVERYDAY
Old Jun 13, 2006 | 03:05 AM
its not the valves, just swap your tps, if it was the valves the throttle position wouldn't matter. and don't beat on it so much, i know its fun, but you want it to last too, even these motors that are made to rev high can only take so much
Old Jun 13, 2006 | 08:41 AM
9WON4's Avatar
stupid question, bro.......do i have to take off my throttlebody to do this procedure?
Old Jun 13, 2006 | 01:43 PM
9WON4's Avatar
becasue the tps is integrated....and i dont know what screws to get once i take it out....
Old Jun 14, 2006 | 04:16 PM
9WON4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littlegreenb18 &raquo;</TD></TR><TR><TD CLASS="quote">its not the valves, just swap your tps, if it was the valves the throttle position wouldn't matter. and don't beat on it so much, i know its fun, but you want it to last too, even these motors that are made to rev high can only take so much</TD></TR></TABLE>
damn....it wasnt my tps.........no change in the misfires........i guess the iacv and valve adjustment are the next few thing on the list......****!!!! wtf is wrong with my motor!
JDM H power
Mar 21, 2009 10:15 PM
OMGWTFBBQ!
11
Jul 30, 2008 11:22 AM
WhiteSH
Aug 14, 2006 10:31 AM
9WON4
Jun 11, 2006 07:48 AM
