Spoon Sports Lower Front Tie Bar [HELP]
Old Jun 10, 2006 | 05:22 PM
Harryflores's Avatar
Default Spoon Sports Lower Front Tie Bar [HELP]
How do I install it??? if you have pics will be better!! HELP Please !!!
Old Jun 13, 2006 | 08:15 PM
George Knighton's Avatar
H-T Order of Merit
Default Re: Spoon Sports Lower Front Tie Bar [HELP] (Harryflores)
Thread reset. Let's try this again.
If you're not going to help, just be quiet.
Old Jun 19, 2006 | 05:49 AM
littleredcivic's Avatar
remove the 2 inner lower control arm bolts, put the bar in, replace the bolts to hold the bar in. have the front of the car off the ground and have a friend help if you are not strong enough to move about 50 lbs of weight with one hand.
Old Jun 25, 2006 | 07:07 PM
Default Re: (littleredcivic)
thanks bro!
Old Jun 25, 2006 | 07:52 PM
cambopheonix56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleredcivic &raquo;</TD></TR><TR><TD CLASS="quote">remove the 2 inner lower control arm bolts, put the bar in, replace the bolts to hold the bar in. have the front of the car off the ground and have a friend help if you are not strong enough to move about 50 lbs of weight with one hand.</TD></TR></TABLE>
Yup. Pretty simple. Good luck
gofast300@gmail.com
Suspension & Brakes
Jan 23, 2009 02:05 PM
CRX EF 88
12
Feb 20, 2008 05:54 AM
sixtodc2
Mar 8, 2006 12:19 PM
Edulerp
Jul 2, 2004 05:53 PM
JDubya
Sep 2, 2002 04:37 AM
