jdm itr lsd in a b16
Old Jun 9, 2006 | 12:51 PM
known's Avatar
Default jdm itr lsd in a b16
to put a jdm itr lsd 4.4 fd into a 2000 b16 civic si tranny what would be needed? final drive from a gsr or type r and im good? i searched but would like to know for sure before i spend some money maybe from someone who has done this. just the final drive gear is needed is what i think?
Old Jun 9, 2006 | 04:12 PM
known's Avatar
Default Re: jdm itr lsd in a b16 (vtecsir1)
bump, someone has to have done this?
Old Jun 10, 2006 | 04:57 AM
Dogginator's Avatar
Daisy... Daisy...
If you switch the final drive ratio, you need to switch the countershaft as well. You should be able to switch your ring gear to the LSD and avoid that mess. You will need the appropriate shim for the differential. Look at the part links in my signature. Make sure that the ITR and Si share the same transmission housing. I think that they do, but have not checked.
Old Jun 10, 2006 | 08:16 AM
SkRiBLaH's Avatar
**LISTEN TO ME**
if the ITR LSD already has a ring gear on it, PUT IT IN. NOTHING ELSE NEEDS TO BE DONE!!!
if the ITR LSD has no ring gear, you need a ring gear from a GSR or ITR.
THAT IS ALL
Old Jun 10, 2006 | 09:41 AM
known's Avatar
Default Re: jdm itr lsd in a b16 (SkRiBLaH)
awesome this is what i was getting at
jdm_coup3
Mar 15, 2007 06:06 PM
turbocivic7901
Nov 28, 2006 10:21 AM
SupaFly_Honda
May 12, 2004 05:12 AM
sirminder
Sep 5, 2003 11:34 AM
