JDM side markers???
search, jesus, you are not the first person that needed a template for a sidemarker install.
http://www.team-integra.net/fo...earch
https://honda-tech.com/zerothread?id=771896
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redDCcoupe »</TD></TR><TR><TD CLASS="quote">i kno for a fact u cant search and find it, </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=979961
and that picture should be all you need to install it. of course you can't have them be perfect, but they will look fine if you have them in the general correct area and they are straight. i can assure you not every DC has the sidemarker in the EXACT same location.
here is another description of how to do it.
"on the bottom corner closest to the front, the southwest corner if you will, the edge closest to the front(west) is flush with the perpendicular line where the body line meets the wheel well. as for the the south edge, its flush with the horizontal tangent of the whell well. find where these lines intersect and thats where the southwest corner of the sidemarker goes.
dry erase markers are your friend. mark those fenders up, measure twice cut once
here is another helpful link i found by searching (no it does not give the exact dimensions but it is a great write-up)
http://www.giuffre.com/persona...s.pdf
"here is another helpful link i found by searching (no it does not give the exact dimensions but it is a great write-up)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redDCcoupe »</TD></TR><TR><TD CLASS="quote">i kno for a fact u cant search and find it, but those pics suck and dont tell anything. i am guessing he needs exact mesurements</TD></TR></TABLE>
I know for a fact if you were to look in the Integra FAQ located at the top of this fourm, There is actually a subject "JDM Sidemarker Install".
How bout them apples?
---Exterior---
http://www.integra.orcon.net.nz/indicator.htm - Sidemarker Install *THANKS RACERMECH*
---Exterior---
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97tegGS »</TD></TR><TR><TD CLASS="quote">
---Exterior---
</TD></TR></TABLE>that is for a DA
---Exterior---
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redDCcoupe »</TD></TR><TR><TD CLASS="quote">i kno for a fact u cant search and find it,</TD></TR></TABLE>
sry everyone i typed it wrong, i ment to say u CAN find it i did not relized i said cant, until 5 sec ago, my bad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .brian. »</TD></TR><TR><TD CLASS="quote">search, jesus, you are not the first person that needed a template for a sidemarker install.
good stuff
good stuff
