I need help with the A/C system...
Old Jun 8, 2006 | 10:41 AM
maivla01's Avatar
Default I need help with the A/C system...
ok, i bough the a/c compressor and it's new i replaced it, but then when i turn on the a/c to test it the clutch doesn't spin. The refigerator air is full, the a/c fuses are fine, i mean verythings look good, but how come there no cold air. any idea?? maybe because of the electric system?? or the switch of the a/c system?? thanks in advanced
Old Jun 8, 2006 | 12:08 PM
maivla01's Avatar
Default Re: I need help with the A/C system... (maivla01)
anyone plz answer my question if u know thanks...
Old Jun 8, 2006 | 12:18 PM
Ruskimafia's Avatar
i had the same problem.. double check the Relays!! might be a bad relay that what happend to me
Old Jun 8, 2006 | 05:40 PM
hondadude's Avatar
with a test light you could check for power to the clutch, Do the cooling fans come on? did you vacum down the system? How much freon did you shove into the system?
Old Jun 8, 2006 | 08:06 PM
maivla01's Avatar
Default Re: I need help with the A/C system... (hondadude)
I tested the clutch with the 12v of electric while turn the A/C on and the clutch did kick in and started to spin. The cooling fan didn't blow and maybe because of the engine not hot enough. anyway about the A/C relay fuse is fine, np with that. I think it's the PRESSURE SENSORY OF A/C...because when it has to have enough pressure acts on the sesory to turn on the switch that leads an electric current toward the clutch and A/C kicked in...but i'm not quiet sure. By the way the Pressure in A/C pipe is 75atm pressure... let me try to change the pressure sensory switch see what happens...thanks for your help... i will post what will happen....
joshiebdapimp
Apr 29, 2013 06:51 PM
jdwheat1
Nov 24, 2012 11:03 AM
whahappened
Acura TSX
Nov 2, 2012 03:20 PM
jjrek9
Jul 31, 2012 07:00 PM
GaHonda
Jun 8, 2011 05:32 PM
