What is the 'mandrel bent'?
Old Apr 15, 2002 | 04:31 PM
'89 hatch's Avatar
Default What is the 'mandrel bent'?
what does it mean an exhaust is mandrel bent?
Old Apr 15, 2002 | 04:39 PM
swtcivic93's Avatar
New User
Default Re: What is the 'mandrel bent'? ('89 hatch)
mandrel bent means that the inside diameter of the pipe doesn't change opposed to crush bent were the pipe is crimped, causing the inside diameter to be smaller in the bends.
Old Apr 15, 2002 | 05:57 PM
Aahj's Avatar
here is a pic of a mandrel bent pipe:
here is a cool link that talks about the differences between crush bends and mandrel bends:
http://www.se-r.net/header_exhaust/m...rush_bends.htm
good luck,
aj
Old Apr 15, 2002 | 06:01 PM
dustin's Avatar
Default Re: What is the 'mandrel bent'? (ajn)
then run a huge "ball bearing" through the pipe while bending to maintain equal pipe diameter throughout the bend.
Old Apr 15, 2002 | 06:25 PM
xci_ed6's Avatar
Default Re: What is the 'mandrel bent'? (dustin)
I am pretty sure they use a mandrel, not a ball bearing. It looks like a metal earthworm.
-Dustin
Old Apr 15, 2002 | 06:27 PM
dustin's Avatar
Default Re: What is the 'mandrel bent'? (Autocratic_1st_Gen)
it's the idea at least...
Old Apr 16, 2002 | 06:36 AM
JustChou's Avatar
It's not a ball bearing - you'd never get it out.
Nisif
May 13, 2006 11:45 PM
EK FLY
Welding / Fabrication
31
Aug 23, 2005 06:50 PM
aziz93
Oct 25, 2003 09:16 PM
Etylorcen
Mar 20, 2002 11:20 AM
redteg1
Jan 23, 2002 08:51 PM
