b16a pistons in a LS (b18b)... uh huh, i'v searched..
Old Jun 8, 2006 | 02:57 AM
. r i c h 9 9 0's Avatar
Default b16a pistons in a LS (b18b)... uh huh, i'v searched..
okay so i'v done a bit of research, and i found the c-speed racing compr. calc and it said that i'l get a comp ratio of 10.8:1 using b16a pistons in a stockass b18b engine.....
so i was just wondering, to the ppl who'v done this, with a jump in compression of 1.6:1 (coz b18b is 9.2:1), what gains would i get with the rest of the engine being stockstandard inside, and the only other mods being i/h/e????
also, im guessing i'd have to get the ecu chipped and tuned to sort out the fuelling if i raise the cr so much??
any idea of what sort of numbers, the b18b has 142 hp at the flywheel if im not mistaken??
will a cr of 10.8:1 be fine to run with pump gas, we get 95 octane from the pumps here in South Africa..
none of the other threads i saw covered the type of power increase one would achieve by doing this......
thanks in advance
-rich
Old Jun 8, 2006 | 04:59 AM
Promina's Avatar
Bump, I would like to know to...
Old Jun 8, 2006 | 05:12 AM
Sam92Teg's Avatar
Default Re: (Promina)
10.8-1 compression is fine with 91 octane if tuned. Usually when compression is raised on a B18a/b, the cams are upgraded also, so I don't know what kind of results you will get with higher compression alone. Install some Crower 403's or 404's cams and upgraded valvesprings, and you will have some very nice gains.
Good luck and let us know how the raised compression alone works out.
Old Jun 8, 2006 | 06:10 AM
hondafan62269's Avatar
Yeah you won't need to run 95, gosh I wish we had that here, upgrading the cams is where you'll see bigger results after the pistons. Make sure you get some sort of a tune after, cause the stock ls ecu is not gonna feed the motor with the right amount of fuel. You should be ok It would be a good start for lsvtec along with some rod bolts.
Old Jun 8, 2006 | 08:50 AM
dohcMONSTER's Avatar
Default Re: (Sam92Teg)
your compression is fine, im runnning 13:1 on 91 pump gas and its fine
Old Jun 8, 2006 | 01:41 PM
-Championship-'s Avatar
76.169.175.137
Default Re: (dohcMONSTER)
?..<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcMONSTER &raquo;</TD></TR><TR><TD CLASS="quote">your compression is fine, im runnning 13:1 on 91 pump gas and its fine</TD></TR></TABLE>how can you possibly run on 91 octane with compression at 13?!!!...it must be pinging like crazy...im also running at the compression at 13:1 and i cant go anywhere without that octane booster,..and i still need higher octane...so tell me
Old Jun 9, 2006 | 12:56 AM
Default Re: (hondafan62269)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondafan62269 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah you won't need to run 95, gosh I wish we had that here, upgrading the cams is where you'll see bigger results after the pistons. Make sure you get some sort of a tune after, cause the stock ls ecu is not gonna feed the motor with the right amount of fuel. You should be ok It would be a good start for lsvtec along with some rod bolts.</TD></TR></TABLE>
man the lowest we get at the coast is 95 we used to have 97 too till the start of the year.. we also had 100 from the one group of petrol stations for a while. that rocked.
anyway, got a price on those pistons from my honda dealer, they work out to the equivalent of $460.. ouch. i hate the exchange rate.
anyway, im gonna look around an see if i can get some anywhere else.. keen for 403's too
so its a given that i'l have to chip the ecu and tune.. uberdata will do the trick, right??
Old Jun 9, 2006 | 01:26 AM
ecks_fourttwo's Avatar
id go with some ctr pistons and some rod bolts.
go lsv with a b16 head and some crower stage 2's and youll see some good power gains. you should be in the low 12:1 range.
tuned to 91 id say you should be some where around the 175's to 190's easy to the wheels...im basing these numbers off of personal experience.
good luck.
Old Jun 9, 2006 | 02:22 AM
lVlemphizStylez's Avatar
Default Re: (. r i c h 9 9 0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . r i c h 9 9 0 &raquo;</TD></TR><TR><TD CLASS="quote">
youd be stupid to pay that much for a set of pistons that barely break 200 a set in the used honda market
Old Jun 9, 2006 | 02:25 AM
Default Re: (lVlemphizStylez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">
youd be stupid to pay that much for a set of pistons that barely break 200 a set in the used honda market</TD></TR></TABLE>
yea, i cringed when i heard the price.. thing is i stay in South Africa, B16a is pretty hard to come across here, but im gonnna look around at scrapyards etc, see what i can find.. else its time to fork out..
Old Jun 9, 2006 | 03:52 AM
Micha's Avatar
FAILWGN
You should PM len. Maybe he can get you a good deal?
Old Jun 9, 2006 | 05:56 AM
Default Re: (Blu99teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blu99teg &raquo;</TD></TR><TR><TD CLASS="quote">You should PM len. Maybe he can get you a good deal? </TD></TR></TABLE>
thanks mate, but i stay in South Africa
im still keen to hear numbers, what whp gain am i looking at here??
Old Jun 9, 2006 | 07:08 AM
Micha's Avatar
FAILWGN
im still keen to hear numbers, what whp gain am i looking at here??</TD></TR></TABLE>
yeah, maybe pm him and see if he can ship them overseas? There has to be something to bring that price down man.
. r i c h 9 9 0
19
Sep 3, 2006 09:32 PM
. r i c h 9 9 0
Jun 9, 2006 11:40 AM
EGkTiOn_CiViC
Jan 10, 2002 12:20 PM
Slopoke
Oct 4, 2001 09:27 PM
VTECRITY
Sep 13, 2001 09:36 AM
