how does this tool called?
Old Jun 8, 2006 | 02:45 AM
RACEPAK's Avatar
Default how does this tool called?
hello
i'm tired of paying to the plumbing store 1$ everytime i want to have a fitting pressed on a line.
i want to buy the tool that presses these things..... how does it called?
thanks
Old Jun 8, 2006 | 07:37 AM
fabnewb's Avatar
Default Re: how does this tool called? (RACEPAK)
i have seen them do it, its a machine.
Old Jun 8, 2006 | 08:13 AM
RACEPAK's Avatar
Default Re: how does this tool called? (fabnewb)
all i know is that it need to be mounted on a table and it has a lever. its not big.
Old Jun 8, 2006 | 08:40 AM
Deviation's Avatar
I'd like to know what its called too.
Old Jun 8, 2006 | 09:54 AM
2kjettaguy's Avatar
Default Re: how does this tool called? (Deviation)
a hydraulic press with the correct die... that machine is expensive... many thousands of dollars.
Old Jun 8, 2006 | 10:11 AM
RACEPAK's Avatar
Default Re: how does this tool called? (2kjettaguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kjettaguy &raquo;</TD></TR><TR><TD CLASS="quote">a hydraulic press with the correct die... that machine is expensive... many thousands of dollars. </TD></TR></TABLE>
nahh... its not hydraulic its manual.
Old Jun 8, 2006 | 10:15 AM
RACEPAK's Avatar
eww eww i found one on google:
http://www.wepf.de/katalog/presse.htm
but its too expensive..... any one knows how makes cheaper ones?
Old Jun 8, 2006 | 10:24 AM
_BEN_'s Avatar
http://cgi.ebay.com/Hose-Crimp...wItem
Old Jun 8, 2006 | 10:06 PM
KFMRC's Avatar
mcmaster carr sell the crimper and most welding supplies have a crimper available also that looks like a vise grip
Old Jun 9, 2006 | 09:17 AM
2kjettaguy's Avatar
Default Re: how does this tool called? (KFMRC)
I didn't know they made manual ones
Old Jun 11, 2006 | 09:38 PM
mr_hahn73's Avatar
Looks like paying the dollatr might be more cost effective at this point!
Old Jun 12, 2006 | 02:16 PM
thaonepointsixdb's Avatar
Brake quip makes one. i use it at work for custom SS brake lines.
its also a hydro one. cant really imagine some one applying 900lbs on a circular item as a hose.
http://www.brakequip.com/systems.html
parasonic
Welding / Fabrication
Oct 26, 2008 06:56 PM
RMF
12
Jun 29, 2006 05:09 PM
MSchu
Honda Motorcycles
May 8, 2006 07:36 PM
cu_jarrett
May 13, 2005 04:36 PM
DoMeStiC-SLAYER666
Nov 13, 2004 06:57 PM
