Starter or Battery problem?
Haven't drove my car for a while. I tried starting it the other day and i had no power to anything. I had a friend come over to jump start it. It fired right up. two days later i tried starting it, and it does not start. Just clicks really bad, i thought my starter might be out, but i had a friend come over to jump it again. It fired right up. So do i need to get a new battery or a starter?
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
sound like you need a new battery. once you get that, i would check to make sure your alternator is charging.
well i jumped it with another car and it fired right up i been starting it everyday and it's starts up fine but sounds a littttle weak on the start up. I will check the battery thanks
go get yourself a auto battery/charging system tester there around $20 if you look around and are a GREAT investment!
Heres an example of one, it will tell you a whole host of proplems.
Im partial to snap on but thats just an example
just hook that guy up to your battery while the car is running and it will tell you if the car is charging it, or if the battery is good as well if the car is off.
Or just head over to autozone and use one of theres, or have them do an electrical system check for you.
Aug 13, 2010 09:14 PM
incognito E46
May 30, 2005 05:06 PM
