still have camber after camber kit installed.
last week i installed my skunk2 pro series camber kit when i got done i notice my driver side still had the same amount of camber so i adjust it, i kept adjusting it til the camber kit was set to +4 (bottom tire popping out). i'm pretty sure i stalled it right. the left camber kit is on the left and the right camber kit in on the right. my drop is pretty low about a finger into my fender. i have a dc4 with 60 series tires( i know, HUGE!) on ls rims. and also my steering wheel is like off by 40 degrees to my right, and dont want to get an alignment until i get this problem solved.
one thing is that i head they dont adjust self installed camber kits that they didnt installed themselves. second they dont want to do my car cause its dropped. anyone have any idea whats causing soo much camber?
When you lower a car the natural geometry is for the car to camber. With a camber kit you can fix this problem but not always 100% stright camber (depending on how low the car is). As for your steering wheel being off that can be fixed with alignment.
I also notice that your talking about the camber only on the drivers side of the car. hmm.... if the car is lowered and your suspension is perfect then both driver and passenger side should have about the same amount of camber. If only your drivers side has camber you have more problems then you think. I would suggest get it look at by a chassis shop.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznvietboi87 »</TD></TR><TR><TD CLASS="quote">dont want to get an alignment until i get this problem solved.</TD></TR></TABLE>
LOL, good luck then..
go to alignment place after 2-3 weeks later if you just installed spring/coilover.
inspector01
Suspension & Brakes
13
Jun 27, 2008 04:12 PM
