trouble with wiring h22 from f22!!!!
im swapping my 97 f22 for a 92-96 vtec h22.... auto to manual.... having trouble with certain parts on the wiring harness not matching up. i need any advise on what to do and ASAP!!! in the middle of swap with the engine out and cant put it in till i figure something out.
i know theres some kind of obd1/obd2 thing but dont know how to do it
Really the OBD thing shouldn't give you any problem. Once you use the H22A ECU and have swapped the engine the immobilizer and such doesn't exist anymore. You probably just don't know what wires to extend and add. If you look in the basic Accord guide it will tell you what wires to extend and add and what pins to swap on the ECU. It would really help if you had the Honda service manual for both vehicles in front of you so you could reference the locations of all the sensors on the wire harness relative to where they are located on the H22A.
