speedometer? not working ... help!
Old Jun 7, 2006 | 08:33 PM
MANDO6669's Avatar
Default speedometer? not working ... help!
okay ... its not like a reall necesity to have a speedometer that works .. buts its nice to know how fast im going when theres a cop behind ... you know what i mean... well when i changed the transmission i took out that like cable thats goes thru the top .. i put in a si tranny (d series motor) and i put that cable back in ... now i have now speedometer ... what can i do to fix it ... ?
Old Jun 7, 2006 | 08:36 PM
CRX2K7's Avatar
New User
Default Re: speedometer? not working ... help! (MANDO6669)
The speedometer is a little piece that slides into the top of the tranny. the SI tranny might have a messed up speedo so you might want to check it. Its to hard to describe what exactly it looks like but its not hard to miss. its kinda a fun time getting it out without breaking it if you dont know what your doing but id say check the actual speedo to see if its cracked broken etc.
Old Jun 7, 2006 | 08:38 PM
charlee's Avatar
did u make sure u put the speedo cable ALL the way in the tranny so the square looking speedo cable is able to catch the gear in the tranny. this happened to me but i didnt take out the tranny just the cable.
Old Jun 7, 2006 | 08:39 PM
MANDO6669's Avatar
i bought the tranny at a wherehouse were they remanfucter them ... i dont think its messed up but if it is then im assed out if it is since my warranty is over on the frickin thing ... it was working before so i dont think the actual speedometer is broken ... i dont know if i got it in all the way and i dont really want to break it trying to get it in there more than im supposed to ...
Old Jun 7, 2006 | 08:42 PM
charlee's Avatar
Default Re: (MANDO6669)
dont trip ***** man. all u have to do is twist it and take ur time trying to get it in.believe me u will know when u get it in. its not that big of a deal. the hardest part of this project is that is way the expletive in tha back.lol
Old Jun 7, 2006 | 08:45 PM
MANDO6669's Avatar
**going outside to play with freakin speed cable**
Old Jun 7, 2006 | 09:08 PM
downest's Avatar
I will give you this one since searching wouldn't find it (it's about tranny fluid), I just happened to have it bookmarked. Original Link
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">At the transmission,pull the inside completely out of the housing:
The entire inner cable should be 34 3/4" long..
If not,it is broken..
If the cable is in one piece,Grease it up and stick it back in the housing:
The green line should be inserted all the way to where the slot is:
It is then held in place with the clip which is usually found inside the rubber cover:
You may have to turn the cable until it lines up with the drive in the sensor...
Old Jun 7, 2006 | 09:19 PM
MANDO6669's Avatar
good stuff ... awesome ... thankz.
pinecone
Apr 12, 2006 01:26 PM
gsrvx
Feb 5, 2005 07:41 PM
