CEL is on. Help me fix this please....
Old Jun 7, 2006 | 07:34 PM
junior40er's Avatar
Default CEL is on. Help me fix this please....
Engine light is on and codes read that the problems are
1)TPS
I cant find this one the shop manual. has anyone dealt with this? Any pics showing where its at?
2)Crankshaft Position Sensor
Is this also known as the Crank Angle Sensor? Ifr so my manual doesnt tell me **** on this. Just tells me what it does. I found the CRAN Angle Sensor hoping its also a Crankshaft Position Sensor and seen that plug has been poorly soldered as if plug was cut before. I hope this is the problem since poor soldering causes higher resistance thus decreasing voltage and invertly affecting sensor reading.
3)IAC
which im assuming is the Idle Air Control Valve. Also damn manual( (chilton manual) doesnt help. Where is this? Im assuming manifold. I heard you can clean these out with carb cleaner. Damn manual doesnt say anything of removal so I can get torque specs.
4)Ignition Output Signal
This also came out in reading for CEL. Which im also assuming is making my tach needle jump all over the place. Is this coming out of the igniter or what??
Also one more thing..Compression test gave me this result:
cyl1) 200psi cyl2)195psi cyl3)190psi cyl4)200psi
is this okay?
Thanks for those who will answer with helpful questions in advance.\par
BTW this is on a 1989 CRX SI with stock D16A6
Old Jun 7, 2006 | 09:26 PM
court's Avatar
25 Year Member
Default Re: CEL is on. Help me fix this please.... (junior40er)
is this due to a dpfi to mpfi swap
Old Jun 7, 2006 | 09:36 PM
downest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junior40er &raquo;</TD></TR><TR><TD CLASS="quote"> Engine light is on and codes read that the problems are
1)TPS
It's on the back of the throttle body, 3 pin plug.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
The crank position, cylinder position, and TDC sensors are all in the dizzy. There is no other crank angle sensor on the actual crank, like some cars have. If someone has messed around with the wiring, best bet is to go back and make sure you know it's right (or try another dizzy).
3)IAC
It's the white plug on the driver's side of the intake manifold, sort of on the fuel injector part of the harness.
Fix your other problems first, but it sounds like you have a bad dizzy or bad dizzy wiring.
is this okay?
BTW this is on a 1989 CRX SI with stock D16A6</TD></TR></TABLE>
Good compression numbers, though you might have some carbon buildup. My A6 ran 180-185 consistently after I rebuilt it to OEM spec.
Old Jun 7, 2006 | 09:37 PM
downest's Avatar
Default Re: CEL is on. Help me fix this please.... (court)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by court &raquo;</TD></TR><TR><TD CLASS="quote">is this due to a dpfi to mpfi swap</TD></TR></TABLE>
Si comes stock MPFI, read the post.
Old Jun 8, 2006 | 05:24 AM
junior40er's Avatar
I think I see the IAC. But some people are telling me its on intake manifold facing the firewall. or is that the Electroinc Air control valve?yeah I also thought crank angle sensor and ignition output was in distributor so would it be easier and cost effective to just replace the distributor itself?
Old Jun 8, 2006 | 05:44 AM
crx_88_si's Avatar
wow thats alot of codes.
1. reset the ecu to clear the codes and make sure they come back, to be certain this isnt a one time error.
2. check all the grounds around the engine and ecu. look for loose wires around the ecu plugs. so many codes might indicate a bad ground.
Old Jun 8, 2006 | 06:59 AM
junior40er's Avatar
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">wow thats alot of codes.
2. check all the grounds around the engine and ecu. look for loose wires around the ecu plugs. so many codes might indicate a bad ground.</TD></TR></TABLE>
well I gotta put a ground fromvalve cover to ground since its missing it. Also plug for crank angle sensor has been cut and desoldered so im oping bad resistance is affecting it. I will try and resolder properly and clear out codes. I reset ECU by unplugging batteries for a period of time right?
Old Jun 8, 2006 | 07:03 AM
crx_88_si's Avatar
you can reset the ecu by pulling the 10a fuse that is labelled as the HAZARD fuse located in the underhood fuse box for 10-20 seconds and replacing it.
that way you can keep your radio stations programmed
Old Jun 8, 2006 | 07:25 AM
downest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junior40er &raquo;</TD></TR><TR><TD CLASS="quote">I think I see the IAC. But some people are telling me its on intake manifold facing the firewall. or is that the Electroinc Air control valve?yeah I also thought crank angle sensor and ignition output was in distributor so would it be easier and cost effective to just replace the distributor itself?</TD></TR></TABLE>
On the newer manifolds, like the Z6, it does face the firewall, but on the A6 manifold it's on the driver's side.
Old Jun 8, 2006 | 09:12 AM
crx_88_si's Avatar
Default Re: CEL is on. Help me fix this please.... (downest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downest &raquo;</TD></TR><TR><TD CLASS="quote">
On the newer manifolds, like the Z6, it does face the firewall, but on the A6 manifold it's on the driver's side.</TD></TR></TABLE>
lol what?
Electronic Air Control Valve = EACV = Idle AIr Control Valve = IACV (they are all the same thing, different names).
they are all on the back of the Intake Manifold, facing the fire wall near the throttle body, 2 hoses (coolant), and 2 bolts hold it on.
Old Jun 8, 2006 | 09:13 AM
junior40er's Avatar
I thnk I know what sensor ur talkin bout but I dont think its it. I think Idle control valve is on manifold firewall side. I'll double check later.
Old Jun 8, 2006 | 11:14 AM
junior40er's Avatar
bump since I actually need to get this fixed.
Old Jun 8, 2006 | 11:16 AM
ludesrv's Avatar
Once in a while my car with throw a TPS code, all I do is pull the fuse for 10 seconds and the code is gone for 2-3 weeks. It's jsut a glitch.
Old Jun 8, 2006 | 02:33 PM
downest's Avatar
Default Re: (ludesrv)
Sorry I was referring to the intake air temp sensor... wrong one.
Old Jun 9, 2006 | 06:19 AM
junior40er's Avatar
Default Re: (downest)
the igniter unit and the Crank/Cyl Angle sensor is inside the distributor. Im thinking it might be better to just replace the unit as a whole. Also screw heads for the TPS sensor are broken off. Any suggestions??
Old Jun 9, 2006 | 06:20 AM
junior40er's Avatar
Default Re: CEL is on. Help me fix this please.... (crx_88_si)
lol what?
</TD></TR></TABLE>yeah thanks. I was thinking that.
Longitudinal
Jul 13, 2011 11:42 AM
hawk__0
Mar 7, 2006 07:52 PM
Black Si
May 4, 2004 03:44 PM
ITR9788
Apr 22, 2004 01:44 PM
hybridEj6
Sep 21, 2003 11:57 AM
