what tool do you guys use to take the main cap bolts off?
Old Jun 7, 2006 | 07:10 PM
Eglifestyle's Avatar
Default what tool do you guys use to take the main cap bolts off?
as the topic said, i was using my impact gun to take the main cap bolts off ight..i took most of them out but there is one that i can not get it out and its getting a little bit strip due to my socket broke on me.. you guys think that i should use a breaker bar to take that sucker out, because that bolts has been sitting there god know how long..and its tight to 86 pound of tourque...any suggestion would be highly appreciate..thanks here are some pics
http://www.we-todd-did-racing....x.jpg
Modified by Eglifestyle at 8:30 PM 6/7/2006
Old Jun 7, 2006 | 07:42 PM
WrongWD's Avatar
try a breaker bar, try anything you can. worse comes to worst, it is a flanged bolt and you could drill off the head
Old Jun 7, 2006 | 07:52 PM
.doeboyfresh.'s Avatar
From: Boswanna,street radio,riddin in da regal. PA.LLday
Default Re: (WrongWD)
i used an air gun
Old Jun 8, 2006 | 12:19 AM
dinko's Avatar
Default Re: (KillaWhoKillacam)
your air gun might not be as strong as u think it is...
i know i remember reading a write-up somewhere where they took a one size smaller socket and heated it up the end....then pounded it onto the bolt...let it cool...then turned that bolt out. thats if the bolt is getting stripped...
you still need some muscle to get it to turn a little bit...call yo daddy into the garage.
Old Jun 8, 2006 | 07:39 AM
Default Re: (dinko)
i used my impact wrench to take it off but all it was doing it was heating up the socket and stripping the damn bolt.. so i guess im going to have to cut the head off the bolt.. so i can take it out.. thanks a lot anyways guys
Old Jun 8, 2006 | 08:37 AM
v4lu3s's Avatar
RTFM
i use a breaker bar since the impact gun can cause damage to bolts. I have also had the machine shop I use say that he would never use an impact gun on engine bolts either.
Old Jun 8, 2006 | 01:00 PM
Combustion Contraption's Avatar
Good lord why are they torqued to 86 ft lb.
Old Jun 8, 2006 | 01:55 PM
Eddiebx's Avatar
Default Re: (Combustion Contraption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">Good lord why are they torqued to 86 ft lb.</TD></TR></TABLE>
yeah seriously, they should jsut torque it hand tight,
Old Jun 8, 2006 | 07:25 PM
Default Re: (Eddiebx)
they are torqued to 86 pounds because who ever owned the motor before me did torque down that way....i dont know what the hell he was thinking.. but they can not be tight by hand because this has a torque spec and you have to follow, image if one of those bolts are not tight enough and the crankshaft comes out of place while you reving at 8500..what could happen
Old Jun 8, 2006 | 07:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">yeah seriously, they should jsut torque it hand tight, </TD></TR></TABLE>
Your a moron. Spec is right around 56.
Old Jun 8, 2006 | 07:37 PM
98vtec's Avatar
moderator emeritus
hahah, i remember when i was breaking down my old h22. The main cap was a mother ******. I got that bitch tho. 4 or 5 beers later and 20lbs head stronger i defeated them.
this was with a 1/2" ratchet with no pipe.
Old Jun 8, 2006 | 08:09 PM
Eddiebx's Avatar
Your a moron. Spec is right around 56. </TD></TR></TABLE>
your the ******* moron who said 86 genius, and i was making fun of your dumb *** for complaing about bolts being torqued too tightly on an engine block, it's something called sarcasm, but thats obviously beyond your mind capacity
Old Jun 8, 2006 | 08:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">your the ******* moron who said 86 genius, and i was making fun of your dumb *** for complaing about bolts being torqued too tightly on an engine block, it's something called sarcasm, but thats obviously beyond your mind capacity</TD></TR></TABLE>
*sigh*
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eglifestyle &raquo;</TD></TR><TR><TD CLASS="quote"> because that bolts has been sitting there god know how long..and its tight to 86 pound of tourque.
And i guess its to much to ask to torque something like a main cap bolt to spec when assembling an engine.
IntegraGSR1999
Suspension & Brakes
May 12, 2010 12:18 PM
B18_Civic
Aug 19, 2005 07:16 PM
MI4$DC5
19
Apr 2, 2005 09:10 AM
Traction
Jul 30, 2004 07:01 PM
VTgringo
Mar 9, 2004 03:04 PM
