13 BARO - atmospheric pressure sensor. weres it located?
are you sure cuz im throwing codes
5.manifold absolute pressure sensor
7.throttle position sensor
13.atmospheric pressure sensor
idk wtf to do with this ****. a mini me gone bad, very bad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">thats the MAP sensor, on top of the throttle body</TD></TR></TABLE>
No. The atmospheric pressure (PA) sensor is inside the ECU on OBD-1 and OBD-2 vehicles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett »</TD></TR><TR><TD CLASS="quote">
No. The atmospheric pressure (PA) sensor is inside the ECU on OBD-1 and OBD-2 vehicles.</TD></TR></TABLE>
yup
yup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett »</TD></TR><TR><TD CLASS="quote">No. The atmospheric pressure (PA) sensor is inside the ECU on OBD-1 and OBD-2 vehicles.</TD></TR></TABLE>
yup its inside your ecu. on obd0 cars its next to the ecu. i hate it when people give wrong information
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">I'v opened up 2 obd2 ecus and there is nothing inside that looks like a sensor..</TD></TR></TABLE>
Just because you don't know what it looks like, that doesn't mean it's not there.
well i did a mini me swap and goin to use the 00ex ecu but it went wrong and jus rippped it out. so right now im useing the y7 head and 00 dx ecu. i tryed switching the map and tb sensor but i jus died when i gave it gas. i cut the wires do you think that can made it expletive up? sorry i know i should have not cut them but its too late now.
I was going to say that you should switch the tps and map sensor plugs and see what happens, that usually solves the problem. Make sure you got the wires right if you cut the plugs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMEK-9 »</TD></TR><TR><TD CLASS="quote">ya i do got them the right way. dont know wha the *** to do........</TD></TR></TABLE>
its inside your ecu like been said 43w9483290 times
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justchilling1 »</TD></TR><TR><TD CLASS="quote">
its inside your ecu like been said 43w9483290 times</TD></TR></TABLE>
And that fixes the Manifold absolute pressure, and throttle position codes how?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red91sit »</TD></TR><TR><TD CLASS="quote">
And that fixes the Manifold absolute pressure, and throttle position codes how?</TD></TR></TABLE>
So many smart *** douche bags around here...
Check to make sure you don't have the TPS and the MAP sensor plugs switched. Sounds like you do. The barometric pressure sensor code will need to be resolved by switching ECU's. There is no "fix" for it once it goes bad. Unless you have a chipped ECU, then you can simply disable it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">
Check to make sure you don't have the TPS and the MAP sensor plugs switched. Sounds like you do. The barometric pressure sensor code will need to be resolved by switching ECU's. There is no "fix" for it once it goes bad. Unless you have a chipped ECU, then you can simply disable it.</TD></TR></TABLE>
damn would it be safe to drive like this? cuz i have to drive to school next week.
as stated above JDM ECUs do not have the baro sensor. Not a big deal unless you change altitude drastically during your drive.
with a good tune disabling the baro sensor will not be noticable at all.
and like everyone has said, if you get this code honda says to clear it, if it comes back replace the ECU.
invisible
34
Mar 16, 2007 07:19 PM
