how much to add a/c to a non a/c car?
Old Jun 7, 2006 | 02:53 PM
rcantu's Avatar
Default how much to add a/c to a non a/c car?
hi guys,
i've been eyeing a lot of swaps and some stock hatches that don't have a/c. It gets hot enough in so cal that I'd want that option.
Any ideas on the cost to retrofit one? thanks
Old Jun 7, 2006 | 02:58 PM
hondakevin21's Avatar
Default Re: how much to add a/c to a non a/c car? (rcantu)
If you figure out a way to do this i've got a b16 a/c condenser i'd sell for cheap.
Old Jun 7, 2006 | 03:22 PM
dynamo's Avatar
Default Re: how much to add a/c to a non a/c car? (hondakevin21)
The hardest part is wiring and setting up all of the components under the dash. The engine bays are the same across all models (ac or non-ac), so everything should bolt right up under the hood and onto the motor (make sure to do the research on what parts you need to make d-series compressors compatible with b-series - p54 bracket). I just put the ac back into my hatch (already pre-wired, just needed the piping and other hardware), and it took about an hour to bolt everything into place.
Old Jun 7, 2006 | 03:30 PM
ThatsTheTruth's Avatar
Default Re: how much to add a/c to a non a/c car? (dynamo)
yeh i was trying to do the same things and i found some kits. i was wondering if it has everything that you would need.
http://cgi.ebay.com/ebaymotors...wItem
Old Jun 7, 2006 | 03:57 PM
ballerchild's Avatar
SO CAL weather sucks right now..
Old Jun 7, 2006 | 04:10 PM
THC07's Avatar
Default Re: (ballerchild)
i feel it up in nor cali eh hot weather, im trying to get voltage to my ac. i also have an extra compressor if needed
Old Jun 7, 2006 | 09:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">i feel it up in nor cali eh hot weather, im trying to get voltage to my ac. i also have an extra compressor if needed</TD></TR></TABLE>
how much are you asking for for the compressor?
Old Jun 7, 2006 | 10:03 PM
red91sit's Avatar
I've actually just removed an entire a/c system from my car, if you need anything lemme know. (except for the shnay underthe dash i dont' wanna deal wtih that)
Old Jun 7, 2006 | 10:08 PM
red91sit's Avatar
Default Re: how much to add a/c to a non a/c car? (ThatsTheTruth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatsTheTruth &raquo;</TD></TR><TR><TD CLASS="quote">yeh i was trying to do the same things and i found some kits. i was wondering if it has everything that you would need.
http://cgi.ebay.com/ebaymotors...wItem</TD></TR></TABLE>
I don't see any electrical relays for the fan motor, (just read said it's not pictured. So yeah looks like everthing you need )
Old Jun 8, 2006 | 08:01 AM
THC07's Avatar
depending on if i can find it and no one else has dibs on it, you can have it for cost of shipping
Old Jun 8, 2006 | 08:49 AM
suspendedHatch's Avatar
Default Re: (THC1107)
I'm selling my complete COMPLETE setup here in San Diego. The only things not included are the bracket mounting it to the block (it's part of my engine mount), the belt, the button on the dash, the "freon", and the plastic box behind the glovebox (but it's internals are yours). The bracket and plastic box you probably don't need anyway. I could be persuaded to get them from the junkyard at your expense if you need them.
https://honda-tech.com/zerothread?id=1539136
Modified by suspendedHatch at 10:03 AM 6/8/2006
crazyguy
Jun 26, 2007 09:58 AM
Wilky
13
Jun 8, 2007 11:07 AM
vietguy
Sep 26, 2006 11:52 PM
gato5254
Jul 25, 2005 07:03 PM
wm5holla
Sep 16, 2003 08:45 AM
