Engine not turning over HELP!!!!
Well since my other thread "another swap wouldnt start" isnt getting any info becuz its so long and no1 wants to read it all..
Im gunna lay down everything right here for the best of help
Problems:
Full pump not priming (Worked 6 days ago before i did swap)
Things replaced:
Starter
Main Relay
New Ecu
Problems:
Things replaced:
Starter
Main Relay
New Ecu
Ok. Engine not turning over definately has nothing to do with the main ralay
or ECU.
Make sure you have a good battery.
Do you have a good and solid connections.
Whether it be the battery ground cables or the positive cable that runs to the starter.
Double check you grounds.
Check your fuses.
Make sure you have the starter signal wire hooked up.
Get your motor to turn over first. Then move on to the other problems.
or ECU.
Check your fuses.
by the way i dont know if this is something to do with it but
the only two things lighting up in my cluster when its on start position is the seatbelt and e-brake lights...
turkeyslow
16
Apr 30, 2008 09:24 AM
Double_Dk
10
Feb 2, 2005 05:11 PM
